gvgbabu Posted June 10, 2011 Posted June 10, 2011 hi all is it possible to delete all texts in a layer by selecting one text because so many entities are there in that layer besides texts (select all wont work) is it requires a lisp program or command is there please help me thanks in advance ganesh Quote
gvgbabu Posted June 10, 2011 Author Posted June 10, 2011 hi alanjt thanks for reply i did not understand please explain in detail and one more question selecting all text in one layer and change it to same text ( ie i have a layer with texts like B1 B2 .....B100, i want to select all the texts and change it to B1) is it possible thank in advance ganesh Quote
BIGAL Posted June 10, 2011 Posted June 10, 2011 Alans given you 4 answers to do this I would "filter" "add object" delete the text value & text position lines, "apply" highlite the whole drawing the press delete button all done. 2nd question yes a simple lisp would change all text values search for change text as a start would need a subtle change to do what you want. Quote
irneb Posted June 10, 2011 Posted June 10, 2011 Yep, Alan's given you 4 commands which are built into ACad for selecting entities by filtering their properties. The SelectSimilar is probably not in your 2004 (unless you've installed something like my lisp from here), but Filter should be fine, perhaps even QSelect. Don't know when SSX came about though. Quote
VVA Posted June 10, 2011 Posted June 10, 2011 The SelectSimilar is probably not in your 2004 I use Alexandr Rivilis SelSim routine ( I think this is the best solution ) + GeomProps Original thread in Russian: GeomProps GeomProps сounts the area as well AcDbBody, AcDbSubDMesh, AcDbPolygonMesh, AcDbPolyFaceMesh. Original thread in Russian: SelSim Quote
irneb Posted June 10, 2011 Posted June 10, 2011 and one more questionselecting all text in one layer and change it to same text ( ie i have a layer with texts like B1 B2 .....B100, i want to select all the texts and change it to B1) is it possible As for this, it's also not necessary to write some Lisp. If it's all normal DText entities, then after you've selected them (using any of the previously listed methods) open the Properties Palette (Ctrl+1) and simply type a new value into the Contents property. If you've got MTexts / Attributes / etc, then use the FIND command: type * as the "Find text string" and your new value into the "Replace with", then click "Replace All". Quote
Tharwat Posted June 10, 2011 Posted June 10, 2011 This might be helpful . (sssetfirst nil (ssget "_x" '((0 . "TEXT")(8 . "[b]YourLayername[/b]")))) Regards. Quote
David Bethel Posted June 10, 2011 Posted June 10, 2011 [b][color=BLACK]([/color][/b]defun c:test [b][color=FUCHSIA]([/color][/b]/ ss[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]= [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b] 1[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.ERASE"[/color] [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"*TEXT"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 8 [b][color=RED]([/color][/b]entget [b][color=PURPLE]([/color][/b]ssname ss 0[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
gvgbabu Posted June 10, 2011 Author Posted June 10, 2011 thanks all of you its works thanks alot ganesh Quote
