Newbie here. I have an extrusion in a plate producing a nipple. I then did a rectangular pattern thus creating 2000 of these nipples. I want to add a chamfer to the end now. But when I select the "parent" nipple and perform the chamfer it does not replicate on to the other 1999 nipples. Is there a specific comand that will do it to all? In AutoCAD I would've made a block and then done the array and modified the block as needed. Any help is greatly appreciated. Thanks much.
Either (1) do the chamfer on the parent first then pattern both the extrusion and the chamfer, or (2) do the chamfer on the parent extrusion and do a duplicate pattern on the chamfer only. Either will give you the same result.
KC
