insulation lineweight
Can we arrange insulation layers?. Normally it just offets the layer that we used in pipe or in duct. I couldnt find any solution for this.
Sure.
Go to Display Manager > Representations by Object > Pipe > Plan > Layer/Color/Linetype. Under the Display Component "Insulation", you can set the Layer, Color, Linetype, Lineweight, LTSCALE, and Plot Style (if you use STB).
Also, be sure to save these settings in your Template file instead of just the current drawing and you'll never have to adjust new files started from here on out.
