Hi to All
I'm working with Civil 3D 2011 and the project was started in 2010. revieved points from a survey,I would convert these points to Civil 3dD point(COGO). When I convert these points the Elevation is not the same Example survet point reads pt#1473,elev#66.73, des. is NG the COGO points after point convert reads pt#73,elev#67.45, des. is NG. There is a .7 differemts from one point to other. Is there a setting that may be off, am I doing something wrong. How not all points are like this,some of the point along the centerline match up.
thank you all that help or read this
brl2008
What exactly do you mean by "convert these points"?
Are you importing an ASCII file into C3D?
thanks for the reply,
sorry it taken so long to come back. the points in question, i'm not sure. the points where in a base drawing before i start working here and the man that inserted them is out of office. when you high lite the node and go to property they read as points. the file for the points is "micrcsoft office excel comma separted value file". i will try to more info to help with my little problem.
thank you
brl2008
