Is there a way to return the total number of layouts in a drawing file?
I would use it to update a field showing the total number of sheets in a set.
(eg 2 of "X", where X is the field variable).
heres one way the variable Len is the number you require
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq len (length plotabs))
Thanks BIGAL.
I do not think that I can use this solution because I am only using LT. Is that correct?
If I break it down, does the code you provided extract a list of all the layout tab names and then count the number of items in that list?
It looks unlikely therefore that I can get a simple variable in the Field dialog box.
Didnt see the LT not sure if you can get around it smae sort of thing how many layers in a drawing theres no variable saved with the total.
  • 1 year later...
Hey BIGAL, this is almost exactly what I need, however is their a way to have it subtract the MODEL tab or just less one?
