mapleleaves Posted June 21, 2011 Posted June 21, 2011 Hi, I have defined extended data property set defintion for my door object. In this door property set definition, one of the properties comes from a location property that was obtained for space object. What is the API to call for reading location property in .NET application? Please advise with example. I tried going through the sample AecPropertySampleMgd but it only show retrieving of manual property defintion and automatic propety defintion. When I called pset.GetValueAndUnitAt(pid) for location property defintion, it will throw a runtime exception eInvalidInput. However, this function works fine for manual property defintion. Please advise. Quote
