vertical horizons Posted June 22, 2011 Share Posted June 22, 2011 In AutoCAD Mechanical 2009, I could type "IMAGEFRAME" then give it a value of "0". This would remove the frame that was around the image, so that the image could not be moved or erased by accident. In AutoCAD Mechanical 2012, whether I give it a value of "0" or "1", the imageframe is still there. What's the deal? Quote Link to comment Share on other sites More sharing options...
Murph_map Posted June 22, 2011 Share Posted June 22, 2011 There's a new varible called "FRAME" that controls it now. It controls all frames, dwf,xref, pdf, images etc. Quote Link to comment Share on other sites More sharing options...
vertical horizons Posted June 22, 2011 Author Share Posted June 22, 2011 There's a new varible called "FRAME" that controls it now. It controls all frames, dwf,xref, pdf, images etc. I tried "FRAME". I chose options "0", "1" & "2". Didn't matter which option I chose, the imageframe still would not turn off. AutoCAD Mechanical 2012 should have made improvements, instead of hindering. They shouldn't remove what works. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 22, 2011 Share Posted June 22, 2011 Maybe you could provide a file or screenshot. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 22, 2011 Share Posted June 22, 2011 This thread has been moved to the Autocad Mechanical section. Quote Link to comment Share on other sites More sharing options...
vertical horizons Posted June 22, 2011 Author Share Posted June 22, 2011 Maybe you could provide a file or screenshot. How can I send the AutoCAD file? Here is a JPG, but I don't think this will help explain my problem. Quote Link to comment Share on other sites More sharing options...
fcapetta Posted March 16, 2012 Share Posted March 16, 2012 Try setting frameselection to '0' Quote Link to comment Share on other sites More sharing options...
