Hawk646 Posted June 22, 2011 Posted June 22, 2011 Can someone offer suggestions as to why a hole feature (prep in weldment) show in the idw? thanks Quote
JD Mather Posted June 22, 2011 Posted June 22, 2011 What state did you select of the weldment when creating the idw view? Attach your files here. Quote
Hawk646 Posted June 22, 2011 Author Posted June 22, 2011 All views were created prior to creating feature. I am editing an existing assy. thank you Quote
Hawk646 Posted June 22, 2011 Author Posted June 22, 2011 Lod = master (holes created in master lod) view = default Quote
Hawk646 Posted June 22, 2011 Author Posted June 22, 2011 CREATING NEW VIEW SHOWS HOLES. PRETTY EXTENSIVE TO REDO ALL VIEWS. i WOULD ATTACH FILES BUT IT IS AGAINST COMPANY POLICY DUE TO PROPRITY. Quote
JD Mather Posted June 23, 2011 Posted June 23, 2011 This was the information I was after. In any case, have you installed all service packs? Did you do an Update of the view? Quote
Hawk646 Posted June 23, 2011 Author Posted June 23, 2011 Thanks! I did not know of the toggles in weldment views - model state. I had re-done the views but this is good information. Again thank you for taking your time to answer. Quote
