CSTAM Posted June 24, 2011 Posted June 24, 2011 I have a drawing with all levels at 3dp e.g 13.346, is there a way of changing all at once to 2dp e.g 13.35? Thank you, Craig Quote
eldon Posted June 24, 2011 Posted June 24, 2011 You do not say whether the levels are simple text or whether they are part of a block attribute. If they are simple text, there is a lisp called TextMath which will do what you want. Quote
