Hi,
I have problem to find any point inside closed polyline.
The point can't be on edge this polyline.
I found example:
http://docs.autodesk.com/ACDMAC/2011/ENU/ObjectARX%20Reference/index.html?frmname=topic&frmfile=AcString.html
but this is for ARX application and I need for Lisp.
The polyline can be any shape eg. http://forum.cad.pl/download/file.php?id=1622&t=1
- figure on top
I have tried with triangles or intersection but without result...
Have someone have any idea?
What about using the boundary command to test if the pl created from the point matches at least part of the original polyline?
Here is some code based on a function written by gile:
[color=GREEN];;----------------------=={ Inside-p }==----------------------;;[/color]
[color=GREEN];;                                                            ;;[/color]
[color=GREEN];;  Predicate function to determine whether a point lies      ;;[/color]
[color=GREEN];;  inside a supplied LWPolyline.                             ;;[/color]
[color=GREEN];;------------------------------------------------------------;;[/color]
[color=GREEN];;  Author: Lee Mac - www.lee-mac.com                         ;;[/color]
[color=GREEN];;  Using some code by gile (as marked below), thanks gile.   ;;[/color]
[color=GREEN];;  Arguments:                                                ;;[/color]
[color=GREEN];;  pt  - 3D WCS point to test                                ;;[/color]
[color=GREEN];;  ent - LWPolyline Entity against which to test point       ;;[/color]
[color=GREEN];;  Returns:  T if supplied point lies inside supplied LWPoly ;;[/color]
([color=BLUE]defun[/color] LM:Inside-p ( pt ent [color=BLUE]/[/color] _GroupByNum lst nrm obj tmp )
 ([color=BLUE]defun[/color] _GroupByNum ( l n [color=BLUE]/[/color] r)
   ([color=BLUE]if[/color] l
     ([color=BLUE]cons[/color]
       ([color=BLUE]reverse[/color] ([color=BLUE]repeat[/color] n ([color=BLUE]setq[/color] r ([color=BLUE]cons[/color] ([color=BLUE]car[/color] l) r) l ([color=BLUE]cdr[/color] l)) r))
       (_GroupByNum l n)
 ([color=BLUE]if[/color] ([color=BLUE]=[/color] ([color=BLUE]type[/color] ent) 'VLA-OBJECT)
   ([color=BLUE]setq[/color] obj ent ent ([color=BLUE]vlax-vla-object->ename[/color] ent))
   ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ent))
 ([color=BLUE]setq[/color] lst
   (_GroupByNum
     ([color=BLUE]vlax-invoke[/color]
       ([color=BLUE]setq[/color] tmp
           ([color=BLUE]entmakex[/color]
             ([color=BLUE]list[/color]
               ([color=BLUE]cons[/color] 0 [color=MAROON]"RAY"[/color])
               ([color=BLUE]cons[/color] 100 [color=MAROON]"AcDbEntity"[/color])
               ([color=BLUE]cons[/color] 100 [color=MAROON]"AcDbRay"[/color])
               ([color=BLUE]cons[/color] 10 pt)
               ([color=BLUE]cons[/color] 11 ([color=BLUE]trans[/color] '(1. 0. 0.) ent 0))
       'IntersectWith obj [color=BLUE]acextendnone[/color]
     3
 ([color=BLUE]vla-delete[/color] tmp)
 ([color=BLUE]setq[/color] nrm ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 ([color=BLUE]entget[/color] ent))))
 [color=GREEN];; gile:[/color]
 ([color=BLUE]and[/color] lst ([color=BLUE]not[/color] ([color=BLUE]vlax-curve-getparamatpoint[/color] ent pt))
   ([color=BLUE]=[/color] 1
     ([color=BLUE]rem[/color]
       ([color=BLUE]length[/color]
         ([color=BLUE]vl-remove-if[/color]
           ([color=BLUE]function[/color]
             ([color=BLUE]lambda[/color] ( p [color=BLUE]/[/color] pa p- p+ p0 s1 s2 ) ([color=BLUE]setq[/color] pa ([color=BLUE]vlax-curve-getparamatpoint[/color] ent p))
               ([color=BLUE]or[/color]
                 ([color=BLUE]and[/color] ([color=BLUE]equal[/color] ([color=BLUE]fix[/color] ([color=BLUE]+[/color] pa ([color=BLUE]if[/color] ([color=BLUE]minusp[/color] pa) -0.5 0.5))) pa 1e-
                   ([color=BLUE]setq[/color] p-
                     ([color=BLUE]cond[/color]
                       ( ([color=BLUE]setq[/color] p- ([color=BLUE]vlax-curve-getPointatParam[/color] ent ([color=BLUE]-[/color] pa 1e-))
                         ([color=BLUE]trans[/color] p- 0 nrm)
                       ( ([color=BLUE]trans[/color] ([color=BLUE]vlax-curve-getPointatParam[/color] ent ([color=BLUE]-[/color] ([color=BLUE]vlax-curve-getEndParam[/color] ent) 1e-) 0 nrm) )
                   ([color=BLUE]setq[/color] p+
                       ( ([color=BLUE]setq[/color] p+ ([color=BLUE]vlax-curve-getPointatParam[/color] ent ([color=BLUE]+[/color] pa 1e-))
                         ([color=BLUE]trans[/color] p+ 0 nrm)
                       ( ([color=BLUE]trans[/color] ([color=BLUE]vlax-curve-getPointatParam[/color] ent ([color=BLUE]+[/color] ([color=BLUE]vlax-curve-getStartParam[/color] ent) 1e-) 0 nrm) )
                   ([color=BLUE]setq[/color] p0 ([color=BLUE]trans[/color] pt 0 nrm))
                   ([color=BLUE]<=[/color] 0 ([color=BLUE]*[/color] ([color=BLUE]sin[/color] ([color=BLUE]angle[/color] p0 p-)) ([color=BLUE]sin[/color] ([color=BLUE]angle[/color] p0 p+)))) [color=darkgreen];; LM Mod[/color]
                   ([color=BLUE]/=[/color] 0. ([color=BLUE]vla-getBulge[/color] obj ([color=BLUE]fix[/color] pa)))
                   ([color=BLUE]equal[/color] '(0. 0.) ([color=BLUE]cdr[/color] ([color=BLUE]trans[/color] ([color=BLUE]vlax-curve-getFirstDeriv[/color] ent pa) 0 nrm)) 1e-9)
           lst
       2
Example test function:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] ss i lst pt ent )
   ([color=BLUE]and[/color] ([color=BLUE]setq[/color] ss ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((0 . [color=MAROON]"LWPOLYLINE"[/color]))))
     ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] ss))
       ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ([color=BLUE]ssname[/color] ss ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))) lst))
     ([color=BLUE]setq[/color] pt ([color=BLUE]getpoint[/color] [color=MAROON]"\nPick Point: "[/color]))
     ([color=BLUE]setq[/color] ent
         ([color=BLUE]vl-member-if[/color]
             ([color=BLUE]lambda[/color] ( x ) (LM:Inside-p ([color=BLUE]trans[/color] pt 1 0) x))
           lst
     ([color=BLUE]vla-put-color[/color] ([color=BLUE]vlax-ename->vla-object[/color] ent) [color=BLUE]acRed[/color])
 ([color=BLUE]princ[/color])
Obviously this will only work with a closed LWPolyline, but wouldn't using an XLine be a lot less legwork, or am I missing something?
[color=yellow](defun _isPointInside (polygon point / temp test)
 (if (vlax-curve-isClosed polygon)
   (progn (setq test (eq (length (vlax-invoke
                                   (setq temp (vlax-ename->vla-object
                                                (entmakex (list '(0 . "XLINE")
        '(100 . "AcDbEntity")
        '(100 . "AcDbXline")
        (cons 10 point)
        (cons 11 (trans '(1. 0. 0.) polygon 0))
                                   'IntersectWith
                                   (vlax-ename->vla-object polygon)
                                   acExtendNone
                         6
          (vla-delete temp)
          test
)[/color]
Nevermind, I didn't think about if the polygon was irregularly shaped. My code is garbage, but I'll leave it there to show my screwup.
For more information, my posted code utilises the Ray Casting algorithm - although there are other algorithms (such as using the winding number of the polygon about the point).
Yep, though I'd say the ray cast is probably the "better" of the 2. The wind-num calcs internal angles ... which won't work on self interesting pls.
BTW I've been looking at making something like this as an addon for OOo Draw, to make a similar thing to Acad's hatch by pick-point. Though it's a lot more complex in sBasic than Lisp! And time is always an issue! :shock:
  • 5 years later...
Hi all,
I have the same question, except the polylines are in an xref.
I have functions that can read the vertices of those polylines.
LM:Inside-p will cast a ray, but won't find a snap point.
So I think of adapting/extending the function
My first thoughts:
- I copy the polylines from the xref and temporarily paste them (with entmake, or so) to the main dwg.
- now LM:Inside-p works
- delete temporary polylines.
Is this the way to go? Does anybody have a better idea, or has anybody already written this?
Is your polyline polygon without arced segments ?
No, it's not guaranteed to have only straight lines. There might be arcs.
It is guaranteed to be closed polylines.
Example: we have an xref "rooms.dwg", containing closed polylines: the shape of the rooms. 1 closed polyline = 1 room; no polylines cross each other, all are on z=0 ...
And there is a text inside with the name of the room.
