Hody!
I have a script file which shows me the value of dimlfac sys variable.
I found in the internet what to do with this file but i do not understand this very well.
Here it is:
For example, store it in file
"my startup script.scr" in folder "c:\myAutoCADCustomisation". Than add to
the autocad icon on the desktop the following:
/p "c:\myAutoCADCustomisation\my startup script.scr"
This part i do not get:
Than add to
Can anybody explain it to me....
Thanks!
M
In essence, this means to Right Click on the AutoCAD Desktop Icon, until you get a box which shows a number of things. Navigate to where it says Properties, and then left click on that.
On the new box that opens, select the Tab named Shortcut; and look what is written into the window next to where it says Target.
Note, that you will need to enter /b "c:\myAutoCADCustomisation\my startup script.scr" at the end of the contents of the window.
Please also see the link below:
http://aec.cadalyst.com/aec/article/articleDetail.jsp?id=142858
Ooo,
Now i got it. I didn't know it before:)
Now i made a script file:
MODEMACRO Dimlfac: $(getvar,dimlfac)
And named it dimlfac.scr.
Does it matter where the file is located when i enter this in this target file location?
Hmm,
This script file does not work like i would like it to work.
If i enter this in the command line it will give me two numbers :(
