muck Posted June 29, 2011 Posted June 29, 2011 I can link AutoCAD Tables to excel files but I don't know how to place a title on that Table. Is there a proceedure to do that? I would like a excel linked table with Bill of Material for its top Title. Thank you, Quote
SLW210 Posted June 29, 2011 Posted June 29, 2011 Select a cell>Right-Click in the cell>Cell Style>Title Quote
muck Posted June 29, 2011 Author Posted June 29, 2011 At this time I have my items Titles (Item, Description, Cat No, Qty & Units) in my first row in my excel file and my AutoCAD table. Should I add a merged cell on the top of my excel spread sheet or I add a row on the top of my autocad table first? Thank you, Quote
muck Posted June 29, 2011 Author Posted June 29, 2011 I did the Proceedure mentioned above but that did not work. It only made bigger text in the far left cell I would like for the title text to run across the top of the AutoCAD table. Quote
muck Posted June 29, 2011 Author Posted June 29, 2011 Another problem in my linked table is when I left justy text. When I do that the cell text hits the left line in the column. Is there a solution to that. Thank you, Quote
SLW210 Posted June 29, 2011 Posted June 29, 2011 Could you post your files here? At least a screen shot. Quote
SLW210 Posted June 29, 2011 Posted June 29, 2011 See if these help.....DATA LINKING I .....DATA LINKING II Quote
muck Posted June 29, 2011 Author Posted June 29, 2011 I have been through those two webpages without any luck. I think it might have something to do with TableStyles but I have had no luck on creating a Title cell on my table. I guess I will keep hunting and picking buttons. AutoDesk has done a good job hidding it. If you have an answer, let me know. Thank you, Quote
muck Posted June 30, 2011 Author Posted June 30, 2011 It should be simple to get a single box Title on top of an table. I found a AutoDesk Publication called "Keep it inside AutoCAD: Data Extraction Direct to AutoCAD Tables" by David Cohn. Publication GD401-P It puts a "Cost Estimate" Title on a table on page 20 but I can't figure out how he does it. The artical mentions example files can be download form AutoDesk Website but it does not give the location so I find them. Another dead end and no Solution. Quote
