tzframpton Posted June 30, 2011 Posted June 30, 2011 Got a real issue maybe. Here's what I've checked: 1. The path is correct in the Support File Search Path, and at the top of the list. 2. The paths are correct in the ACADDOC.LSP file and they are. 3. The LISP files which are pathed using the (load) command is correct, and they are. If all these are correct, what could stop it from working? Any ideas? Quote
SLW210 Posted June 30, 2011 Posted June 30, 2011 Are there any other copies of acaddoc.lsp? It will load the first one found. Quote
SLW210 Posted June 30, 2011 Posted June 30, 2011 You may have the ACADDOC.LSP VIRUS. ACADDOC.LSP VIRUS II Quote
BlackBox Posted June 30, 2011 Posted June 30, 2011 ? (findfile "acaddoc.lsp") Edit: You said the paths are correct in the SFSP, and within acaddoc.lsp, not where acaddoc.lsp is located according to ACAD. Quote
tzframpton Posted June 30, 2011 Author Posted June 30, 2011 Command: (findfile "acaddoc.lsp") "C:\\Users\\tframpton.DELL4600\\1-autocad\\acaddoc.lsp" It find's it. Quote
SLW210 Posted June 30, 2011 Posted June 30, 2011 Place at end of acaddoc.lsp file. (princ "\n*** My acaddoc.lsp loaded *** ")(princ) Hit F2 after opening a drawing and see if it tried to load. Quote
tzframpton Posted June 30, 2011 Author Posted June 30, 2011 AH............. Found the problem. The first path in the ACADDOC.LSP file was broken. I updated a program from Lee Mac. Little did I know it would not skip over and load the rest of the paths!!! Ah, whew. I thought something really went wrong there, lol. Thanks a million once again guys. Man, just seemed so simple, sometimes I get mad at myself for not checking the obvious..... Quote
ReMark Posted June 30, 2011 Posted June 30, 2011 Just be glad it wasn't a virus although you would have had several acaddoc.lsp files not one. Quote
