I am unable to plot PDF files from my AutoCad 2011. Plots OK in Word etc so Windows 7 printer seems ok. Get error message : Job: - Canceled
Job ID: 8
Sheet set name:
Date and time started: 4/07/2011 11:48:32 AM
Date and time completed: 4/07/2011 11:48:33 AM
UserID: user
Profile ID: AutoCAD 2011 Prosteel Ribbon
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Number of warnings: 0
Sheet: - Canceled
File: D:\Projects\P079 - PDG Engineering for Standard Stacking Conveyor\C Drawings\dwgs\P079-BMSPR01-0000-SS-DR-0059 to 0066.dwg
Category name:
Page setup:
Device name: Adobe PDF_A3.pc3
Plot file path:
Paper size: A3
MESSAGE: Error : A StartDocPrinter call was not issued.
ERROR: The device has reported an unknown error.
Job: - Canceled
What software are you using to create the PDF?
Did you create the Adobe PDF_A3.pc3 file? You might need to look at the Custom Settings in that file.
Separate to that, I recommend you use the default "DWG to PDF.pc3" file. Since 2010 it improved to the point where we stopped using 3rd party PDF creators altogether.
Thanks for your help. That solved the problem. I obviously had some Custom Settings that were not compatible.
Now use "DWG to PDF.pc3" with success.
Thank you again.
I'm glad it worked out. I feared it would be more complicated than that.
