If you model a spere, render it and drop the opacity, so that you can see anything which was inside. And give your 3d model the usual backgroung "The Sun"
The sun will cause a yellow shadow from the spere, is there a way of turning the shadow off for individual objects ?
p.s im using AutoCAD 2010
I use the properties icon with the object selected and turn shadows off. There might be better ways of doing this.
