I am trying to make a one step procedure for a common plot used in my office. I created a basic LISP to perform the task so that anyone in the office could use it and get the same results. My problem is I keep getting an error message that tells me the output device I want to use cannot be found. Could someone take a look at my LISP and see if there is something I am doing wrong? This LISP works in AutoCAD 2010 but I get this error when working in AutoCAD 2009. Most of the users in the office are on 2009.
CANON_ARCH-D_FLW - example.lsp
Should have posted the LISP this way for easy reading...
;;Purpose: This command will auto-plot an ARCH-D size print to the canon plotter with a user specified plot scale
(DEFUN C:Archd (/ scale )
   (setq scale (getstring "Enter Plot Scale: "))
(command "-plotstamp" "off" "")
(COMMAND "-PLOT" "YES" "model" "\\PGEFS01\\WORKGROUP\\AUTOCAD\\PLOT FILES\\CANON IPF600 ARCH-D.PC3" "" "INCHES" "LANDSCAPE" "NO" "EXTENTS" scale "CENTER" "YES" "FP-Lineweights.CTB" "YES" "AS DISPLAYED" "NO" "NO" "YES")
(PRINC)
Is plotstamp in 2009 can not remember if not you can do a version check "acadver" last number is what you want 2011=18.1 and not run
(if ((lambda (vrsn)
       (cond
        ((vl-string-search "R17.2" vrsn) (setq appstr "6.0")) ;09
        ((vl-string-search "R18.0" vrsn) (setq appstr "7.0")) ;10
        ((vl-string-search "R18.1" vrsn) (setq appstr "8.0")) ;11
        ((vl-string-search "R18.2" vrsn) (setq appstr "9.0")) ;12 ?
       ((alert "This version of C3D not supported!"))
      (vlax-product-key)
     )                         ; end if condition progn is true
Yes, plotstamp is supported in 2009. The part of the LISP 2009 gets hung up on is finding the output device. I want it to locate a (.pc3) file that I have already set up on the server, which all users have access to. However this is not working for me. It works perfectly fine in 2010 but can not be located in 2009.
This is what I use and it works across the office:
;Based on PageSetups from Alan J. Thompson
(defun c:A1 ()
(PlotReactorOFF)
 (if (findfile "T:/Drawing Tools/Templates/CCC2009.dwt")
     (command "_.psetupin" (findfile "T:/Drawing Tools/Templates/CCC2009.dwt") "A1")
     (while (wcmatch (getvar "cmdnames") "*PSETUPIN*")
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
(command "-plot" "n" "" "A1" "" "n" "y" "n")
(command "_-purge" "a" "*" "N")
(setq CCC_Sheet "A1")
(command "updatefield" "all" "")
(command "regenall")
(command "_zoom" "e")
 (initdia)
 (command "._plot")
(PlotReactorON)
;(princ)
(defun PlotReactorON nil
 (vl-load-com)
 ;; © Lee Mac 2010
 (  (lambda ( data foo / react )
      (if (setq react
            (vl-some
              (function
                (lambda ( reactor )
                  (if (eq data (vlr-data reactor)) reactor)
              (cdar
                (vlr-reactors :vlr-command-reactor)
        (if (not (vlr-added-p react))
          (vlr-add react)
        (setq react
          (vlr-command-reactor data
            (list
              (cons :vlr-commandwillstart foo)
      (if (vlr-added-p react)
        (princ "\n** Reactor Activated **")
        (princ "\n** Reactor Failed to Activate **")
      react
   "Plot-Reactor"
   'Plot-Callback
(defun PlotReactorOFF nil
 (vl-load-com)
 ;; © Lee Mac 2010
      (if (setq react
            (vl-some
              (function
                (lambda ( reactor )
              (cdar
          (vlr-remove react)
      (if (or (not react) (not (vlr-added-p react)))
        (princ "\n** Reactor Deactivated **")
        (princ "\n** Reactor Failed to Deactivate **")
      react
   "Plot-Reactor"
   'Plot-Callback
(defun Plot-Callback ( reactor arguments )
 (vl-load-com)
 (if (eq (strcase (car arguments)) "PLOT")
   (LM:Popup "Warning" 64 "Gotcha!!!   Please use the NNRDO Plot tools when plotting standard layouts!!")
(defun LM:Popup ( title flags msg / WSHShell result )
 ;; © Lee Mac 2010
 (setq WSHShell (vlax-create-object "WScript.Shell"))
 (setq result   (vlax-invoke WSHShell 'Popup msg 0 title flags))
 (vlax-release-object WSHShell)
 result
@woodman - I have not been able to get your LISP to work for what I need. Thank you for the LISP though. I will continue to work on it.
I have figured out how to get 2009 to recognize the output device but now I have another problem. I don't know how to get the paper size to change to what I want.
(DEFUN C:Archc (/ scale )
   (setq name (findfile "w:/AUTOCAD/PLOT FILES/CANON IPF600 ARCH-c.PC3"))
(COMMAND "-PLOT" "YES" "model" NAME "[i][color=black]Paper Size[/color][/i]" "INCHES" "LANDSCAPE" "NO" "EXTENTS" scale "CENTER" "YES" "FP-Lineweights.CTB" "YES" "AS DISPLAYED" "NO" "NO" "YES")
(PRINC)
The output I need is "ARCH C (18"x24")" however I can not figure out a way to get that to work because of the Parentheses in the name. Anyone know of a way I can do this? Maybe a setq variable or something of that nature??
The problem is not the parentheses, but rather the extra apostrophes in the string, you will need to prefix these with a backslash escape character to mark them as literals.
"ARCH C (18\"x24\")"
You can realise the correct syntax when using code editors which offer syntax highlighting such as the Visual LISP IDE, Notepad++, etc.
I apologize, I meant the apostrophes. Thanks Lee Mac I'll give this a go.
I don't set the paper size in the lisp. I have created page setups and call them from the lisp. They are stored in the template drawing. I have 1 template size for A1 and A3 and when the user calls either A1 or A3 plot the lisp loads a different page setup. I have done the same for pdf's as well.
For us it works very well.
I have never tried to use a template file to do the settings for a print before. I will have to look into that.
Thanks for the information.
