I have a VBA code loaded in AutoCad. In this code I connect to a database (access) to store data from 3dpolylines in the drawing. In this process I want to check the new selected line with the first and the last entry of the database (so i can add the selected lines to the line stored in the database).
For this i make a record set of the database to figure out what the size is. This wount work as is should be!!
    SQL = "SELECT Nr FROM Polyline"
   Set rsline = DB.Execute(SQL)
   MsgBox rsline.RecordCount
   rsline.MoveLast
The rsline.recordCount gives a value -1
And the movelast command gives ann error. Automation error (Error 440)
(It apears that only the rsline.movenext works properly. So i can write a loop with rsline.movenext until rsline.eof = true, but this database will be quite large so I don't prefer this option.)
Can someone give me a clue on how i can tackle this problem
This one worked for me:
Option Compare Database
Option Explicit
Sub test()
Dim rsline As DAO.Recordset
Dim Db As DAO.Database
Set Db = CurrentDb
Dim SQL As String
   Set rsline = Db.OpenRecordset(SQL)
   MsgBox "Number of records are: " & rsline.RecordCount
   rsline.MoveLast
   MsgBox "Polyline number is: " & rsline!Nr
   ' close and clean up 'rsline' and 'Db' here if you need it
End Sub
~'J'~
The problem was that I used an ADO database and not a DAO now i changed that the problem is gone. Thanks for the advise
I am glad you have solved a problem
Cheers :)
~'J'~
