Hello,
I'm having problems with some drawings obtained from a structure analysis program. The program exports the results into .dwg but it exports text in an annoying way and I can't seem to change the text style. I tried exploding the text but it doesn't work. The problem is worse because I have loads of drawings that I need to export and I can't waste time changing the all the text manually. Can anyone help?
Here is the file: http://dl.dropbox.com/u/20022600/TEXT%20PROB.dwg
You will probably need to search Google for a lisp or program, unless using Qselect, then properties, change the text style, would be sufficient.
Can you explain the "annoying way" bit.
I have no trouble in changing the text style. The text as I saw it was ordinary text, so I am puzzled as to why you tried to explode it. :?
Once you have identified a solution, I am sure that someone will be able to suggest a batch way of alterations.
