anette_nilsson Posted July 11, 2011 Posted July 11, 2011 I want to rename several structures but it seems not to work. In the Civil 2009 it worked, but in 2011 something goes wrong. Menu: Pipes/Utilities/Rename nw parts Select first: I do Select next: f ex 10 structures away. Then the dialogbox appears, but it says just 1 structure selected. Ok: just the last selected structure will be renamed. If I cancel the command, the first selected structure is still selected, but I cant unselect it by Esc. I have to select it again and then it can be unselected by Esc. It seems to do anything with the zoom-function. If I just select a few structures without zooming the renaming works, nearly every time, but not a larger amount of structures. If I use the ribbon-menu, I can't select many structures. I appreciate some help. Quote
SLW210 Posted July 11, 2011 Posted July 11, 2011 What are your computer specs? What graphics card? Maybe you can post some images? Quote
anette_nilsson Posted July 11, 2011 Author Posted July 11, 2011 I have following specifications: Windows 7 Enterprise Proc: Intel Core(TM2) Duo CPU T9400 2,53 Ghz RAM: 4,0 GB System: 64-bit NVIDIA Quadro FX 770M DAC Type: Integrated RAMDAC Available Graphics memory: 2269 MB Video memory: 512 MB Shared system memory: 1757 MB Hope this is the information you want? Don't know what images to send to you, it doesn't show anything on the screen, just one selected structure. Quote
SLW210 Posted July 11, 2011 Posted July 11, 2011 I am not sure if this could be your problem, but you are at the minimums for running Civil 3D 2011 on 64-bit. What is PICKFIRST = ? 64-Bit AutoCAD Civil 3D 2011 Windows 7 Enterprise, Ultimate, Professional, or Home Premium (64-bit); Windows Vista Enterprise, Business, Ultimate (SP1 or SP2, 64-bit); or Windows XP Professional x64 Edition (SP2, 64-bit). AMD Athlon 64, AMD Opteron, Intel® Xeon with Intel® EM64T support, Intel® Pentium® 4 with Intel EM64T support. 4 GB RAM minimum required, 8 GB RAM minimum recommended. 7 GB disk space with 2 GB free after installation. 1,280 x 1,024 true color video display adapter (true color) 128 MB or greater, Pixel Shader 3.0 or greater, Direct3D®-capable workstation-class graphics card. 1,600 x 1,200 or greater recommended. Multiple monitors are supported. Microsoft® Internet Explorer® 7.0 or later. DVD drive. Quote
