Hello,
Im trying to produce a mapping programme within Autocad that allows a user to select an area from an image based map and load in digital mapping data.
The user should be able to select an area and load it into a frame of there size and at any selected scale.
Heres the coding i have so far, which should load the map, however it doesnt seem to be working as im getting a debug error with GetPoint. Could anyone help me with this as its driving me crazy!
Private Sub CommandButton1_Click()
Dim clickPoint As Variant
Dim dblclickPoint(0 To 2) As Double
Me.Hide
clickPoint = ThisDrawing.Utility.GetPoint(Prompt = "Select a point on map...")
dblclickPoint(0) = clickPoint(0)
dblclickPoint(1) = clickPoint(1)
dblclickPoint(2) = 0
'Create some varibles to insert map block / file
Dim mapBlock As AcadBlockReference
Dim blockInsert(0 To 2) As Double
blockInsert(0) = 0
blockInsert(1) = 0
blockInsert(2) = 0
If dblclickPoint(0) > 390000 And dblclickPoint(0) > 395000 And dblclickPoint(1) > 295000 And dblclickPoint(1) < 300000 Then
MsgBox ("You chosen the North West")
Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "T:/SO99NW.dwg", 1, 1, 1, 0)
End If
If dblclickPoint(0) > 390000 And dblclickPoint(0) > 395000 And dblclickPoint(1) > 290000 And dblclickPoint(1) < 295000 Then
MsgBox ("You chosen the South West")
Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "T:/SO99SW.dwg", 1, 1, 1, 0)
End If
Me.Show
End Sub
Cheers!
Edited by SLW210
Add tags
You need to use code tags (#) for your code. I have moved this to the .NET, ObjectARX and VBA forum.
Try changing:
to:
clickPoint = ThisDrawing.Utility.GetPoint(, vbCr & "Select a point on map...")
when i click on a point it just opens the main form again.
Try changing the two red greater than symbols to less than symbols. If you don't you will never enter the if statements.
Me.Hide
blockInsert(0) = 0
blockInsert(1) = 0
blockInsert(2) = 0
If dblclickPoint(0) > 390000 And dblclickPoint(0) [b][color=red]>[/color][/b] 395000 And dblclickPoint(1) > 295000 And dblclickPoint(1) < 300000 Then
End If
If dblclickPoint(0) > 390000 And dblclickPoint(0) [b][color=red]>[/color][/b] 395000 And dblclickPoint(1) > 290000 And dblclickPoint(1) < 295000 Then
End If
Me.Show
End Sub
And check the syntax of your block insertion!
nope still the same :(
Errors with this bit:
See post 4 and change
Nah mate it doesnt work. When i click on a point it just opens the form again.
I've tried your code with the changes to the > symbols and because I don't have a T: drive I created blocks in the drawing to simulate your DWGs and it all worked fine. Have a look at your insertion of your DWGs, the problem must be there. Good luck.
It didnt work. Could you show me how you have your coding?
I created a new project and inserted a module and a form.
The code for the module is:
Option Explicit
Sub Maps()
   UserForm1.Show
End Sub
The form (UserForm1) has one button (CommandButton1) and the code for the form is:
Option Explicit
   Me.Hide
   clickPoint = ThisDrawing.Utility.GetPoint(, "Select a point on map...")
   blockInsert(0) = 0
   blockInsert(1) = 0
   blockInsert(2) = 0
   If dblclickPoint(0) > 390000 _
   And dblclickPoint(0) < 395000 _
   And dblclickPoint(1) > 295000 _
       Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "SO99NW", 1, 1, 1, 0)
       'Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "T:/SO99NW.dwg", 1, 1, 1, 0)
   End If
   And dblclickPoint(1) > 290000 _
       Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "SO99SW", 1, 1, 1, 0)
       'Set mapBlock = ThisDrawing.ModelSpace.InsertBlock(blockInsert, "T:/SO99SW.dwg", 1, 1, 1, 0)
   End If
   AcadApplication.Update
   Me.Show
End Sub
I created two sqares in my drawing based on your coordinates and two blocks SO99NW and SO99NW.
In your code I changed your get point to:
and I changed twice
to:
I also added this line:
to update the drawing and make the changes immediately visible.
Run the macro Maps, select one of the areas and it works just as expected.
It worked fine yesterday at home and it also works fine today in the office. I'm using AutoCAD 2012 and haven't testewd it on other versions, but there's nothing in there to stop it working on other versions.
When you click on a point, does it open the form again? because thats what happens to me.
Yes it does, but that's what your code implements with the Me.Show. But it inserts the block before it re-shows the form and if you then click in the other area it hides the form, inserts that block and then re-shows the form. If you don't want the form to show again after you have inserted your block then replace the Me.Show with End and that will quit your macro without re-showing the form.
