I'm Trying to get the name of Block "fix_a" as "bkname_a".
For normal block, both A and B below works, but not for dynamic block.
A:
(setq bkname_a (cdr (assoc 2 (entget (car fix_a)))))
B:
(setq fix_an (cdr (assoc '-1 (entget (car fix_a)))))
(setq bkname_a (vla-get-name (vlax-ename->vla-object fix_an)))
When it comes to dynamic block, the "bkname_a" gets some string starts with "*", such as *U211, *U7.
This stirng is not the blockname, but one-to-one correspondent to the blockname.
I can't understand what's happening.
Please help me if you know how to get the name of dynamic block !!
Additionally, when I tried to use the script below, I can bet the blockname.
http://cadtips.cadalyst.com/content/block-quantify?print=1
Edited by SLW210
With dynamic blocks the block name always starts with an *, but the "Effective Name" holds what is the block name in a normal block.
I'm not sure how to deal with that in LISP as I've only ever done in VBA, but no doubt one of our LISP experts will show you how it can be done. Can you use ENTSEL or ENTGET to list the DXF codes of the dynamic block and then see with which code the name you are looking for is associated?
For dynamic block you should use it like this .
(vla-get-Effectivename (vlax-ename->vla-object (car (entsel "\n Select a Dynamic block :"))))
Hope they don't miss.
Opps ...... You may mean the variable :o
Huh? What variable? :huh:
No... I simply meant that if the user failed to select an object, let alone one without the applicable EffectiveName Property, an error will be returned.
Lee's already provided the solution (by way of VVA's posted links), and he's not even in this thread (yet?). LoL
The variable which is (setq ename ........
You're right , since the OP is already know how to handle that and just looking for the correct function , I left it for them . :)
Regards.
Meh - I'm leaving this alone. :sigh:
No he's not in this thread yet, but you can bet your bottom dollar he's watching :roll:
:wink: ......
Thank you all for the advises.
Now I got the "Effective name" and that is what I needed.
As I'm beginner and don't understand the discussion of "variable",
You all saved me from the labyrinth !:)
Don't feel bad - You're not the only one who didn't understand. :?
