Huibert Posted October 8, 2008 Posted October 8, 2008 I encounter an error when selecting a polyline (the same code works fine for 3dpolyline, line and arc) Dim Pick As Variant Dim Polyline As AcadPolyline ThisDrawing.Utility.GetEntity Polyline, Pick, vbCr & "Select the polyline" I tried to find the problem but the only thing I found is that when selecting a polyline, the entity is not of type AcadPolyline. Why?? And how can I select a polyline? Dim Pick As Variant Dim Polyline As AcadPolyline ThisDrawing.Utility.GetEntity Ent, Pick, vbCr & "Select the polyline" If TypeOf Ent Is AcadPolyline Then Set Polyline = Ent End If Quote
SEANT Posted October 8, 2008 Posted October 8, 2008 Autodesk has made it a bit confusing with the various polyline entities and how they are referred to in the application versus API context. The bottom line for your situation is: Dim LWPolyline As AcadLWPolyline . . . . If TypeOf Ent Is AcadLWPolyline Then Set LWPolyline = Ent Quote
Huibert Posted October 8, 2008 Author Posted October 8, 2008 Thanks for the solution. The program works as it should. Thank you very much Huibert Quote
