Organic Posted July 13, 2011 Posted July 13, 2011 This is probably a stupid question, although I can't remember how to do the following (fairly sure it is possible): I was sent a drawing where the same block (block A) resides on multiple layers. I isolate one of the layers and want to change all the blocks (A) on this layer to a different block, block B. However, I cannot edit the block definition as block A must remain the same on the other layers. So how do I replace/change one block to another block when I have the blocks I want to change selected? Quote
Tyke Posted July 13, 2011 Posted July 13, 2011 Freeze all the layers except the one with your blocks on. Place a sample of your new block on the layer and then use the Express Tools function Replace Blocks. Don't forget to delete your sample block :wink: Quote
Organic Posted July 13, 2011 Author Posted July 13, 2011 I actually tried that before and couldn't get it to work as needed. I tried it again, this time freezing all the other layers (rather than just isolating my desired layer). The problem is it converts all instances of the block in the drawing to the new block (including those on the frozen layers which I want to retain as their original/old block definition). Quote
Tyke Posted July 13, 2011 Posted July 13, 2011 You can do it with LISP and VBA, have you had a look on Lee Mac's site to see what he has? Quote
Tyke Posted July 13, 2011 Posted July 13, 2011 Here's some VBA code that will do what you want: Option Explicit ' Tyke 13.07.2011 Sub SwapBlocksOnLayer() Dim booPickedOrg As Boolean Dim booPickedRep As Boolean Dim oEnt As AcadEntity Dim varPos As Variant Dim brefOrgBlock As AcadBlockReference Dim brefRepBlock As AcadBlockReference Dim strOrgBlockName As String Dim strRepBlockName As String Dim strBlockLayer As String Dim lngBlockCount As Long Dim colSelSets As AcadSelectionSets Dim objSelSet As AcadSelectionSet Dim ssBlocks As AcadSelectionSet Dim strSSName As String Dim vCodeB As Variant Dim vDataB As Variant Dim iCode() As Integer Dim vData() As Variant START: lngBlockCount = 0 ' select block to be replaced booPickedOrg = False ' nothing selected ' loop until something is selected Do While Not booPickedOrg ThisDrawing.Utility.GetEntity oEnt, varPos, "Select the block to be replaced: " If oEnt Is Nothing Then booPickedOrg = False Else ' if something has been selected If oEnt.ObjectName = "AcDbBlockReference" Then strOrgBlockName = oEnt.Name ' original block name strBlockLayer = oEnt.Layer ' layer name Exit Do ' quit the loop End If End If Loop ' select replacement block booPickedRep = False ' nothing selected ' loop until something is selected Do While Not booPickedRep ThisDrawing.Utility.GetEntity oEnt, varPos, "Select the replacement block: " If oEnt Is Nothing Then booPickedRep = False Else ' if something has been selected If oEnt.ObjectName = "AcDbBlockReference" Then strRepBlockName = oEnt.Name ' replacement block name booPickedRep = True Exit Do ' quit the loop End If End If Loop ' check if they are the same block If strOrgBlockName = strRepBlockName Then MsgBox "You picked the same block twice, try again", vbOKOnly GoTo START End If On Error Resume Next Err.Clear Set colSelSets = ThisDrawing.SelectionSets ' ####################### create the selset for the blocks ############################# strSSName = "ssBlocks" ReDim iCode(4) ReDim vData(4) For Each objSelSet In colSelSets If objSelSet.Name = strSSName Then colSelSets.Item(strSSName).Delete Exit For End If Next Set ssBlocks = colSelSets.Add(strSSName) ' set filter values iCode(0) = -4: vData(0) = "<and" ' filter = and start iCode(1) = 0: vData(1) = "insert" ' text entities iCode(2) = 2: vData(2) = strOrgBlockName ' block name iCode(3) = 8: vData(3) = strBlockLayer ' layer name iCode(4) = -4: vData(4) = "and>" ' filter = and end vCodeB = iCode vDataB = vData ' populate selection set with just the text on the layer ssBlocks.Select acSelectionSetAll, , , vCodeB, vDataB ' if selset is empty exit sub If ssBlocks.Count = 0 Then Exit Sub ' ################## end of create the selset for the blocks ############################# ' swap the blocks For Each brefOrgBlock In ssBlocks ' swap the block varPos = brefOrgBlock.InsertionPoint Set brefRepBlock = ThisDrawing.ModelSpace.InsertBlock(varPos, _ strRepBlockName, 1#, 1#, 1#, 0) ' set blocks properties brefRepBlock.Layer = strBlockLayer ' delete existing block brefOrgBlock.Delete ' increment counter lngBlockCount = lngBlockCount + 1 Next brefOrgBlock ' update screen Application.ActiveDocument.Regen acAllViewports MsgBox CStr(lngBlockCount) & " blocks swapped (" & strOrgBlockName & " for " & strRepBlockName & " on layer " & strBlockLayer & ")", vbOKOnly End Sub It works fine for me. Quote
Lee Mac Posted July 13, 2011 Posted July 13, 2011 This code will use the shortcut of renaming the selected references so that they reference a different block definition, but, although there is less legwork, there are some assumptions and drawbacks to this method: Assumes replacement block definition is present in the drawing Will not work with attributed blocks (since attributes are 'separate' from the block definition). (defun c:brsel ( / b1 ss ) (vl-load-com) (if (and (princ "\nSelect Block to be Inserted...") (setq b1 (ssget "_+.:E:S" '((0 . "INSERT") (2 . "~`**") (66 . 0)))) (setq b1 (cdr (assoc 2 (entget (ssname b1 0))))) (princ "\nSelect Blocks to be Replaced...") (ssget "_:L" (list '(0 . "INSERT") (cons 2 (strcat "~" b1)) '(66 . 0))) ) (progn (vlax-for obj (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (vla-put-name obj b1) ) (vla-delete ss) ) ) (princ) ) Quote
