AutoLISP: Help for beginner
luiscarneirorm
Your English is good.
Are the ENTITIES (the objects drawn in modelspace) assigned an individual lineweight, or are they all set to ByLayer, and the LAYER is assigned a lineweight?
this is the biggest problem, because some are an individual lineweight and other are bylayer.
  • Replies 65
  • luiscarneirorm
    33
  • BlackBox
    12
  • Lee Mac
    11
  • Tharwat
    5
Posted Images
Maybe something like this as an example:
(defun c:test ( / df ls lw )
   (while
       (and (setq lw (getreal "\nSpecify LWeight: "))
           (or
               (< lw  0.0)
               (< 2.11 lw)
       (princ "\nLineweight must be 0.0 <= x <= 2.11")
   (if lw
           (setq lw (fix (* 100 lw)))
           (while (setq df (tblnext "LAYER" (null df)))
               (if (= lw (cdr (assoc 370 (entget (tblobjname "LAYER" (cdr (assoc 2 df)))))))
                   (setq ls (cons "," (cons (cdr (assoc 2 df)) ls)))
           (sssetfirst nil
               (ssget "_X"
                   (cons
                       (cons 410 (if (= 1 (getvar 'CVPORT)) (getvar 'CTAB) "Model"))
                       (if ls
                           (list
                               (cons -4 "<OR")
                               (cons 370 lw)
                               (cons 8 (apply 'strcat (cdr ls)))
                               (cons -4 "OR>")
                           (list (cons 370 lw))
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if lw
           (sssetfirst nil
               (ssget "_X"
                   (cons
                       (if ls
                           (list
                               (cons -4 "<OR")
                               (cons 370 lw)
                               (cons -4 "OR>")
Thanks, it works.
The only difference is that I wanted to select entities with greater than linewight=0.2 for example, but this is already very very useful.:)
I think with a little research I can adjust myself to my purpose :D
Sure, this was just an example. :)
One more thing, it is possible to translate a macro to a Lisp function?
I have this macro that calls some functions, but if one gives the error, the macro stops.
overkill
all
[color=red]F7[/color]
-LAYER NEW CHEIO COLOR 1 CHEIO SET CHEIO
[color=red]HB[/color] ALL
[color=red]E2PO[/color] ALL
[color=red]F5[/color]
ALL
[color=red]TROCALL[/color]
ALL
TXTEXP
-LAYER OFF CHEIO Y
PURGE ALL N
-LAYER NEW A01-20 COLOR 1 A01-20
-LAYER NEW A02-20 COLOR 2 A02-20
-LAYER NEW A03-20 COLOR 3 A03-20
-LAYER NEW A04-20 COLOR 4 A04-20
-LAYER NEW A05-20 COLOR 5 A05-20
-LAYER NEW A06-20 COLOR 6 A06-20
-LAYER NEW A07-20 COLOR 8 A07-20
-LAYER NEW A08-20 COLOR 11 A08-20
-LAYER NEW A09-20 COLOR 25 A09-20
-LAYER NEW L01 COLOR 1 L01 L DASHED L01
-LAYER NEW L02 COLOR 2 L02 L DASHED L02
-LAYER NEW L03 COLOR 3 L03 L DASHED L03
-LAYER NEW L04 COLOR 4 L04 L DASHED L04
-LAYER NEW L05 COLOR 5 L05 L DASHED L05
-LAYER NEW L06 COLOR 6 L06 L DASHED L06
-LAYER NEW L07 COLOR 8 L07 L DASHED L07
-LAYER NEW L08 COLOR 36 L08 L DASHED L08
-LAYER NEW L09 COLOR 21 L09 L DASHED L09
-LAYER NEW L09 COLOR 75 L09 L DASHED L09
-LAYER NEW L1W50 COLOR 1 L1W50 L DASHED L1W50
-LAYER NEW L2W50 COLOR 2 L2W50 L DASHED L2W50
-LAYER NEW L3W50 COLOR 3 L3W50 L DASHED L3W50
-LAYER L DASHED 0 SET 0
-LAYER OFF 0 Y
[color=red]F4[/color]
ALL
FLATTEN N
[color=red]TROCALLL[/color]
red funccions it's lisp funccions
sorry this is very confusing, but as I said I am new to AutoLISP and my inglish is not very good (translator)
For commands inside *.lsp, you can use :
(command "_.commandname" "commandfunction1-cf1" "cf2" "cf3" ... "") witch will execute that command and always return after execution : nil, or
(vl-cmdf "_.commandname" "commandfunction1-cf1" "cf2" "cf3" ... "") witch will execute that command and always return before execution : T
For calling other *.lsp previously loaded into CAD memory, you can use :
- for command functions (defun c:functionname ( arg1 arg2 ... / var1 var2 ... ) ... )
calling from your *.lsp : (c:functionname arg1 arg2 ...)
- for non command functions (defun functionname ( arg1 arg2 ... / var1 var2 ... ) ... )
calling from your *.lsp : (functionname arg1 arg2 ...)
M.R.
Hello Marko,
Welcome to CADTutor - I know you're not new to LISP, but....
SLW get's angry when you forget to use
, and you wouldn't like him when he's angry. ;)
M.R.
sorry but it is very confusing to me.
I made this script works perfectly, my problem is for example:
the script selects all "mtext" and explode them, but if there is no "mtext" gives error and does not perform any further function.
Command: F5
Select objects: ALL 0 found
Select objects:
No previous coordinate system saved.
Error: Function cancelled
; error: An error has occurred inside the *error* functionFunction cancelled
Can i use "IF" in scripts???
Please post the code for F5.
Edit:
You can use LISP in scripts, or your script can call a LISP routine (as is shown above).
;Seleciona todos os textos
(defun c:f5(/ cSet)
 (setq cSet(ssget
              '((0 . "TEXT,MTEXT"))
            ); end ssget
   ); end setq
 (if cSet
     (princ(strcat "\n" (itoa(sslength cSet)) " found."))
     (sssetfirst nil cSet)
     ); end progn
    (princ "\nNothing found. ")
   ); end if
 ); end of c:f5
this is the f5 funccion.
That works perfectly, my problem is when there is no text in the drawing.
While I would personally write the F5 function differently, it (F5) does not *appear* to be the cause of the error you posted:
Command: F5
Select objects: [color=red]<EndF5>[/color] ALL [color=red]<BeginTROCALL>[/color] 0 found
Select objects:
Perhaps, if you were to outline exactly what it is you are trying to do (in entirety), we might be able to better suggest options, rather than addressing one tiny step at a time?
My problem is when there is no text in the drawing, because if there is text the script continues to the next function and explode the text and change it to a new layer and performs other functions, but no text when the script stops running.
Then you need to revise your LISP.
For example, instead of this (in your script):
ALL
... Use this as your F5 LISP:
(defun c:F5 ( / ss)
 (if (setq ss (ssget [color=red]"_x"[/color] '((0 . "TEXT,MTEXT"))))
     (princ (strcat "\n" (itoa (sslength ss)) " found."))
     (sssetfirst nil ss))
   (princ "\nNothing found. "))
 (princ))
... This way, if there are no Text, or MText, then nothing is selected.
If you still have an error as a result of nothing being selected at the F5 step, then that means the next step(s) (i.e., TROCALL LISP), are not written correctly.
Hope this helps!
Edited by BlackBox
I ALWAYS see the typos AFTER I hit submit!
My biggest problem is I can not even explain ... :cry:
My script is working well, the only thing I'm missing is to prevent a case of not having any text in the drawing, the the script has to jump to the function "-layer off cheio y"
[color=red][color=black](...)[/color]
f5[/color]
all  [color=red]
trocall[/color] [color=red]
f5[/color]
all
txtexp
-layer off cheio y
luiscarneirorm,
In order to accomplish this, you need to incorporate LISP.
As an example, if you were to use your script to call a *new* LISP routine.
Script:
(load "NewLISP.lsp")
NewLISP
NewLISP.lsp:
(defun c:NewLISP ()
 (vl-load-com)
 ((lambda (acDoc / _makelayer _LayerItem ss)
    (defun _makelayer  (name color ltype lnwt)
      ;; Lee Mac, 2011
      ((lambda (_function)
         (_function
           (list
             (cons 0 "LAYER")
             (cons 100 "AcDbSymbolTableRecord")
             (cons 100 "AcDbLayerTableRecord")
             (cons 2 name)
             (cons 70 0)
             (cons 62 color)
             (cons 6 ltype)
             (cons 370 lnwt))))
        (if (tblsearch "LAYER" name)
          (lambda (data)
            (entmod (cons (cons -1 (tblobjname "LAYER" name)) data)))
          entmakex)))
    (defun _LayerItem (layerName)
      (if (tblsearch "layer" layerNmae)
        (vla-item (vla-get-layers acDoc) layerName)))
    (foreach lsp  '("overkillsup" "overkill")
      (vl-catch-all-apply 'load (list lsp)))
    (acet-overkill2 (list (ssget "_x") 0.000001 nil nil nil nil))
    [color=red];; <- c:F7 here[/color]
    (_makelayer "CHEIO" 1 "Continuous" -3)
    [color=red];; <- c:HB here
    ;; <- c:E2PO here
    ;; <- c:F5 here
    ;; <- c:TROCALL here
    ;; <- INSTEAD of c:F5 here:[/color]
    (if (setq ss (ssget "_x" '((0 . "MTEXT,TEXT"))))
      (vla-put-layeron (_LayerItem "CHEIO") :vlax-false))
    (vla-purgeall acDoc)
    (foreach lay '(("A01-20" 1 "Continuous" -3)
                    ("A02-20" 2 "Continuous" -3)
                    ("A03-20" 3 "Continuous" -3)
                    ("A04-20" 4 "Continuous" -3)
                    ("A05-20" 5 "Continuous" -3)
                    ("A06-20" 6 "Continuous" -3)
                    ("A07-20" 8 "Continuous" -3)
                    ("A08-20" 11 "Continuous" -3)
                    ("A09-20" 25 "Continuous" -3)
                    ("L01" 1 "Dashed" -3)
                    ("L02" 2 "Dashed" -3)
                    ("L03" 3 "Dashed" -3)
                    ("L04" 4 "Dashed" -3)
                    ("L05" 5 "Dashed" -3)
                    ("L06" 6 "Dashed" -3)
                    ("L07" 8 "Dashed" -3)
                    ("L08" 36 "Dashed" -3)
                    [color=red];;("L09" 21 "Dashed" -3)                             ;<- duplicate?[/color]
                    ("L09" 75 "Dashed" -3)
                    ("L1W50" 1 "Dashed" -3)
                    ("L2W50" 2 "Dashed" -3)
                    ("L3W50" 2 "Dashed" -3))
      (vl-catch-all-apply '_makelayer lay))
    (vla-put-layeron (_layerItem "0") :vlax-false)
    [color=red];; <- c:F4 here[/color]
   (vla-get-activedocument (vlax-get-acad-object)))
 (princ))
** Note - This is the best *example* I can provide, given that I do not know what code you are including in the functions in red.
I hope this helps!
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if lw
           (sssetfirst nil
               (ssget "_X"
                   (cons
                       (if ls
                           (list
                               (cons -4 "<OR")
                               (cons 370 lw)
                               (cons -4 "OR>")
Lee Mac, or someone else, can you help me to change this function to select all entities with linetipe are not continuous? And as in this case, I also have some entities with linetipe bylayer, and others with individual linetype.
I think it should be simple (adapt this exemple) but for me it is still very confusing the lisp linguage, and the dxf codes :oops:
Thanks for the help. I am enjoying this language, but it's hard for me, I'm accustomed to program in simple language.
P.S.: RenderMan, thanks for your post, but I think I'll leave that for later (it's hard for me, for now:cry:)
