pleasehelpme Posted July 15, 2011 Posted July 15, 2011 my friend sent me a autocad plt file but i cant open it because autocad 2011 doesn't recognize it at all do you guys have any idea how i can open it view it and edit it and if you have any plt to dwg converters that would be good too. sincerely, pleasehelpme Quote
ReMark Posted July 15, 2011 Posted July 15, 2011 (edited) View the PLT file with any of the following: AutoManager View SPLOT ViewCompanion AutoVue CAD Viewer Normica Plot File Manager If you have to edit the file ask your friend to resend it in DWG format. What version of AutoCAD is he using? Edited July 15, 2011 by ReMark Source: CADforum Quote
pleasehelpme Posted July 15, 2011 Author Posted July 15, 2011 i dont know what version of autcad he is using also he is more like a business partner by any chance is there a plt to dwg converter? Quote
SLW210 Posted July 15, 2011 Posted July 15, 2011 type PLT2DWG on the command line or Express>Modify>File Tools>Convert PLT to DWG Quote
rkmcswain Posted July 15, 2011 Posted July 15, 2011 (edited) type PLT2DWG on the command line or Express>Modify>File Tools>Convert PLT to DWG That only works on really old HP-GL format plot files. my friend sent me a autocad plt file but i cant open it... Do you really need to open it or just plot/print it? Do you realize that a plot file is not a DWG? Even if you get a program that supposedly converts from PLT to DWG, you will be missing accuracy, layers, blocks, etc. Read more: http://cadpanacea.com/node/17 Edited July 15, 2011 by rkmcswain addition Quote
