taiwanchu
 Share
I have a drawing with an xref clipped several times and laid out but now cannot select them. I have run an audit, recover, purge to all xrefs and the parent file. The xref had some errors so I wblocked the whole drawing out and replaced it which at first helped but then the parent file still had the same problems. Some text in the parent file is not selectable either until a full reboot of Acad. Any suggestions?
you may need to post the file for someone around here to take a look at, I personally don't have time currently but i'm sure someone else around here will be willing to take a look at it for you.
 Share
