Qonfire Posted July 15, 2011 Posted July 15, 2011 (edited) Hello I hope I'm in right section to ask my questions I want to make a price list using attributes in block and then extracting them to cell matching some cells with excel While in data extr wizard for some reason I cant get the size column to set in ascending order..tried many things then decided to ask this question Why does size 10 brake the logic? Can I edit the extracted data without launching data extr wizard? Data extr wizard brings a data in one table what if I want the table to display other types of attribute ( example see pic for instance instead of EL i have SS no problem until now, but my matched data link in excel is for EL and not for SS) Its hard to explain Basicly i selected the column in excel for one type of attribute "EL" and I want fo a different name of same attribute different cell matching I will tryto explain better lately if need to see pic Looking forward to hear your comment ext.data.dwg Edited July 15, 2011 by Qonfire Quote
Spinxy Posted July 19, 2011 Posted July 19, 2011 would calling them 01, 02, 03, 04, 10, 11, 12 help? Quote
Qonfire Posted July 21, 2011 Author Posted July 21, 2011 Guys what should i Select in data Extr wizard to get the readings of series dimension on one layer preferably Spinxy haven't tried yet looks like it will work thank you for advice Quote
