mintyfresh Posted July 18, 2011 Posted July 18, 2011 Ladies and Gentlemen of CT. Kindly view the two objects below. I would like to take the flat 3D object on the right and turn it into a circular 3D object like that on the left. I want to do this in AutoCAD or Inventor. Is it possible? If so, how? Quote
stevsmith Posted July 18, 2011 Posted July 18, 2011 Start a new sketch and draw a line from the mid point of the long length and make it perpendicular to the opposite side. Exit the sketch and use the form command. Enter the bend radius (equal to the inside radius of your cylinder) Quote
