muck Posted July 19, 2011 Posted July 19, 2011 I am learning about inertance & Shadowing in VB.net before interfacing VB.net with AutoCAD. I am having problems with Shadowing concept. Is there any good tutorials that keeps these oop concepts simple with simple examples? Thank you, Quote
Jeff H Posted July 19, 2011 Posted July 19, 2011 Here is one example where VB differs. A good book about Visual Basic or google should help http://msdn.microsoft.com/en-us/library/ms172785.aspx To show a example how they differ *****EDIT********* Code will not format correctly it puts it on one line [color=blue]Public[/color] [color=blue]Class[/color] [color=#2b91af]Shape[/color] [color=blue]Overridable[/color] [color=blue]Sub[/color] Draw MsgBox([color=#a31515]"Base Draw"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]Sub[/color] SaveToDatabase MsgBox([color=#a31515]"Base SaveToDatabase"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]End[/color] [color=blue]Class[/color] [color=blue]Public[/color] [color=blue]Class[/color] [color=#2b91af]Rectangle[/color] [color=blue]Inherits[/color] [color=#2b91af]Shape[/color] [color=blue]Public[/color] [color=blue]Overrides[/color] [color=blue]Sub[/color] Draw() MsgBox([color=#a31515]"Overrides Draw"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]Shadows[/color] [color=blue]Sub[/color] SaveToDatabase MsgBox([color=#a31515]"Shawdows SaveToDatebase"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]End[/color] [color=blue]Class[/color] [color=blue]Public[/color] [color=blue]Class[/color] [color=#2b91af]Triangle[/color] [color=blue]Inherits[/color] [color=#2b91af]Shape[/color] [color=blue]Public[/color] [color=blue]Overrides[/color] [color=blue]Sub[/color] Draw() MsgBox([color=#a31515]"Overrides Draw"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]Shadows[/color] [color=blue]Sub[/color] SaveToDatabase MsgBox([color=#a31515]"Shawdows SaveToDatebase"[/color]) [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]End[/color] [color=blue]Class[/color] Now when you use them in this context you can see the difference [color=blue]Dim[/color] rec [color=blue]As[/color] [color=#2b91af]Shape[/color] = [color=blue]New[/color] [color=#2b91af]Rectangle[/color] rec.Draw() rec.SaveToDatabase() [color=blue]Dim[/color] tri [color=blue]As[/color] [color=#2b91af]Triangle[/color] = [color=blue]New[/color] [color=#2b91af]Triangle[/color] tri.Draw() tri.SaveToDatabase() Quote
muck Posted July 20, 2011 Author Posted July 20, 2011 I think understand overwriting but I am having a tough time with vb.net Shadowing. What does shadowing mean in programming? Is there any good simple examples? An example that includes a test routine that uses the shadow routine. Please keep it simple as possable. thank you, Quote
Jeff H Posted July 20, 2011 Posted July 20, 2011 Maybe someone else can explain better but if you understand overrides then I would guess you have a basic understanding of inhertance and polymorphism. Some people might argue that shadows is not a OOP concept and you should not use it. But other than taking the information from these links and posting what they already say, these links give a good description. http://msdn.microsoft.com/en-us/library/c4swkw24.aspx http://msdn.microsoft.com/en-us/library/ms172785.aspx http://msdn.microsoft.com/en-us/library/hya04w5b.aspx http://msdn.microsoft.com/en-us/library/10kws135.aspx http://msdn.microsoft.com/en-us/library/b25c8bbc.aspx Quote
muck Posted July 21, 2011 Author Posted July 21, 2011 I guess I need to start form the bottom with a good oop tutorial that gets to the point. I have been searching the web but it seems like I get lost because there is too much info. Is there a oop tutorial that that gets to the point and is short and somewhat simple? I am sure it is going to take some time to absorb oop info. I want to work on inhertance and polymorphism so I can understand those concepts. Thank you, Quote
