T704 Posted July 19, 2011 Posted July 19, 2011 IS IT POSSIBLE TO MOVE MULTIPLE TABS FROM ONE DRAWING TO ANOTHER? AND IF SO HOW. THANKS. (LIL BIT OF BACKGROUND USING LAND DESKTOP AND HAVE POINT IN ONE FILE THAT IS ASSOCIATED AND THE OTHER FILE CONTAINS THE PAPERSPACE ELEMENTS I NEED, DON'T WANT TO WASTE TIME w/ COPY PASTE EACH AND EVERY ONE.) Quote
rkent Posted July 19, 2011 Posted July 19, 2011 You can copy the layout tabs through DesignCenter, drag and drop, anything in PS will be copied over. Quote
Cad Monkey 2 Posted July 20, 2011 Posted July 20, 2011 I found these instructions to be really helpful and probably easier / more direct than the design center method: http://lynn.blogs.com/lynn_allens_blog/2009/01/an-autocad-hip-tip-on-copying-layouts-from-one-drawing-to-another.html works great. Hold down the control key if you want to select multiple tabs to copy. Quote
rkent Posted July 20, 2011 Posted July 20, 2011 I found these instructions to be really helpful and probably easier / more direct than the design center method: Click and drag and drop from Design Center is pretty straight forward but nice to know other ways to do the same thing. Quote
amarcon Posted July 20, 2011 Posted July 20, 2011 Thanks, I like both answers. Better than the ways I've seen some kludge this..... Quote
SLW210 Posted July 20, 2011 Posted July 20, 2011 Click and drag and drop from Design Center is pretty straight forward but nice to know other ways to do the same thing. +1 I think DC is easier, but nice to have an alternative. I renamed your thread so that it will be easier to search. Quote
Cad Monkey 2 Posted July 20, 2011 Posted July 20, 2011 I might have tried the Design Center method, but I don't use it much and couldn't even find it. Where is it in 2011? On one of the Ribbon tabs? Probably right in front of my face... Quote
ReMark Posted July 20, 2011 Posted July 20, 2011 You can type the letters "DC" at the command line and it should bring up the Design Center. Quote
