I don't have this problem on all my files, only a select few. When i save a file and reopen, all the viewports in which I have frozen layers are all reset. All layers are turned back on and I have to go through every viewport and refreeze layers. This problem has persisted long enough that I unfortunately know when I close a file I will have to reorganize the layers next time I open the file. Is this a setting issue or this a bug in the file?
Welcome to CADTutor, and congrats on your first post!
Sounds like a VISRETAIN System Variable issue... perhaps setting VISRETAIN=1 will resolve the issue.
Thanks that worked!!! I appreciate your help!
You're welcome. :)
