I have the following problem: I have loads of lines in 3D, some longer, some very short. With PE i can join them using fuzz, but since some lines are next to another line then it tends to make the line go back and forth in some places. What i want to do is somehow make an average line from all the other lines.
Any ideas?
There's a command in Express Tools called Overkill. Give that a try.
Express>Modify>Delete duplicate objects
_PLINE select the first endpoint, select the next endpoint until finished, hit ENTER.
Search around and see if someone has a LISP already.
Are you using AutoCAD?
