CiCAD Posted July 22, 2011 Posted July 22, 2011 I explode a block that contains a Polyline. when i explode it it converts the pline into a line. i need it to remain a Pline for maching purposes. How do i fix this. Note this is only the case when the block has been mirrored then exploded. I tried mirroring the pline in the block. this does not help....... Quote
nestly Posted July 22, 2011 Posted July 22, 2011 The "Polyline" is probably a relic 2D Polyline rather than a newer lightweight polyline. Use CONVERTPOLY to change it within the block unless it has to be a heavy polyline for some reason. Quote
CiCAD Posted July 22, 2011 Author Posted July 22, 2011 Yes that works although i have no idea the difference between the two Quote
nestly Posted July 22, 2011 Posted July 22, 2011 Bursting a mirrored block still turns 2D Polylines within the block into lines. Quote
SLW210 Posted July 22, 2011 Posted July 22, 2011 How about not exploding blocks? What happens if you explode the block first and then mirror? Quote
