Testing Assembly Contraints
I work with some reasonably large assemblies and there are alway possible issues with things not being fully constrained and it not being noticed until it is too late.
Is there a way to test an assembly (and all sub-assemblies) to confirm they are all fully constrained?
you can design sub assemblies in different files and make sure they are associative. For instance i do a lot of designing with air cylinders. I can build an air cylinder model assembly and import this assembly into a new file. Having said that i usually start my constraints from scratch a few times during a model because of issues:)
In the modeling side you can drive constraints. Usually i just modify their offsets, for the air cylinder example. I will have the piston constrained to the bore of the cylinder body. By changing this offset(say from 0 to 4 inches) it moves the rest of my assembly(assuming its right). If you do this throughout a model you will be fine.
thanks for the post. I may not have explained myself properly. I understand driven constraints and how they work. What I want to do is have Inventor highlight to me any part or assembly that is not fully constrained and therefore may move in an unexpected/undesired way. I can manually do this but it is a long slow process and was hoping some automation could help out.
My main project has evolved through 2 other designers (over 3 years) and without being rude their constraint methods, part numbering and general CAD philosophy were less than perfect, since taking over design control I have been trying to clean up the model but I know there are places where constraints have fallen off. Every now and then I notice another part that is not fully constrained and I just want a way to double check the the complete model is fixed. I hope that makes sense.
yes it does makes sense but as far as i know there isnt a check for this, because it is not required that an object be fully constrained. The newest version I am using is inventor from 2007 so im not sure if the new inventor has a more comprehensive design check other than interference/collision.
There should be a degrees of freedom option in view that would help. Though it can get pretty difficult to look at if you have lots of parts.
