I need help with printing!!!!
i'm using autocad 2010. i've draw a house plan and ready to plot. i've set the plot style and everything. but nothing was printed on the paper and tried for like 3 to 4 times but still the same. both of my black and color ink cartridge are full. :o HELP!!
Do you see it when you do a print preview?
yes! :o are all the lines suppose to be very thin when print preview? i mean no lineweight.
If you're trying to plot with lineweights, then lineweight should show on the preview. Can you post a screenshot of your Plot dialog box?
You didn't draw everything on a layer called Defpoints did you?
id check your layer settings and see if the current layer with all the data on is set to print or not.. Also, have you generated a layout for your model yet?
Did you select a printer? If as in Nestly's screen shot above, it says "none" next to "name" then nothing happens.
[ATTACH]28885[/ATTACH]
I haven't plotted from Modelspace for many years, but nothing seems out of place to me. Perhaps uncheck "plot with plotstyles" and if you can print, then I'd say there may be something wrong with your CTB
I don't know whether you have successfully plotted yet, but I would make a couple of comments which might prove useful.
I see you are plotting the display. when I plot from Modelspace, I usually plot a Window, so that I know what is likely to be printed. Always use the Preview.
Your scale of 1 to 100 seems curious when you are plotting with Inches units. The scale of 1/8" to 1' is 1 to 96, and if you are wanting 1" to 100', that is a scale of 1 to 1200. When I am in doubt as to what will fit on the paper, I first use the Fit to paper, see what scale it comes up with, and then choose the precise scale that I want.
Of course, when you discover Paperspace plotting, then your troubles might be over :?
oh...okay when i do the print preview, this is what i see...is this correct? or else?
I am afraid that the image is not visible to me. But generally, the Preview shows what is going to be printed.
Either your layer is on defpoint or your plot is off
check your layer first
and then go layer properties manger and check your plot....
problem with printing solved.....but there is another problem.. when i do the print preview, my plan looks okay with layers.. when i print it, it came out black?? what's wrong again? :|
Do you have a color plot style table selected?
