BCamel Posted July 25, 2011 Posted July 25, 2011 Hello All, when I import a dxf from Cam-duct to Autocad 2012 the size of the part grows slightly (a couple mm), If I check the part in Opus it measures correct. I have been messing with this for a while now but am no closer to an answer. Regards. Quote
BCamel Posted July 26, 2011 Author Posted July 26, 2011 Thanks for replying SLW210, the scale is already set to 1 and this is happenning on two of three machines (all set to a scale of one) I'm more curious if this is an Autocad or Cam-Duct error, I don't even bother trying to get support from TSI or Maps anymore as I can't wait a year for an answer. Quote
SLW210 Posted July 27, 2011 Posted July 27, 2011 From an AutoCAD perspective, it is a Cam-Duct error. In my opinion it can be simplified by saying it is more or less a communication error and is pretty much the norm for non-AutoCAD DXF. You can probably search around for a better and more technical answer. I am too busy today. Quote
BCamel Posted July 27, 2011 Author Posted July 27, 2011 You are right, we realized there was a constant in the amount of growth of each dxf, it turned out to be the Kerf value was being added by Cam-Duct to the dxf before exporting. We haven't figured out how to stop the Kerf being added yet but at least we know where the error is coming from. Quote
