Hello there, here i am with another doubt that i hope to clarify with your help. How do i put a point at a certain distance along the length of a line, i mean, i have a curved line with curves to both side more less like a spline, and now i wanna put a point on that line on every 5m. i hope you understand what i mean,
Thank you very much in advanced ;)
That is nice, but from what i got "measure" splits the line into equal segments but does not put the point at the precise distande i want...
P.S-Sorry guys, thats just perfect for what i want ;)
thanks NBC
MEASURE puts a point (or a block) at specified distances along other entities. DIVIDE will put a point (or a block) at a specified number of segments along the entity.
Try this LISP, similar what you want, you may also need to generate a point along your curve at a specific distance.
aquired this code from ipseifer if i remember
(defun c:xdiv(/ *error* cCurve curPt dPar dPt
      enPt fPar fPt maxLen obType oldDis
      oldOsn posDir rClose sFlag stPt
      sumDis swMod undoLst vClose whatDo)
 (vl-load-com)
 (defun asmi_GetActiveSpace(/ actDoc)
   (if
     (= 1(vla-get-ActiveSpace
    (setq actDoc
    (vla-get-ActiveDocument
      (vlax-get-acad-object)
      ); end vla-get ActiveSpace
     ); end setq
    ); end vla-get-ActiveDocument
 ); end =
     (vla-get-ModelSpace actDoc)
     (vla-get-PaperSpace actDoc)
     ); end if
   ); end of asmi_GetActiveSpace
 (defun RestorePointStyle()
   (if
     (and xdiv:oldPm xdiv:oldPs)
(initget "Yes No")
(setq swMod
     (getkword
       "\nRestore point style? [Yes/No] <No>: "))
(if(null swMod)(setq swMod "No"))
(if
 (= swMod "Yes")
    (princ "\nPlease wait... \n")
    (setvar "PDMODE" xdiv:oldPm)
    (setvar "PDSIZE" xdiv:oldPs)
  ); end progn
 ); end if
); end progn
     ); end if
     ); end of RestorePointStyle
 (defun AddPointOrInsert(Mode Block Scale)
   (vla-AddPoint
 (asmi_GetActiveSpace)
      (vlax-3d-point curPt))
   ); end of AddPointOrInsert
 (defun AddPointOrInsert(Mode Block Scale / outObj)
   (setq undoLst
    (append
     (list
(list
 (setq outObj
   (vla-AddPoint
      (vlax-3d-point curPt))); end setq
  curPt xdiv:curDis
); end list
      ); end list
        undoLst); end append
 ); end setq
   outObj
 (defun *error*(msg)
   (if cCurve
 (vla-Highlight cCurve :vlax-false)
   (setvar "OSMODE" oldOsn)
  ); end progn
); end if
    (princ "\n*Cancel*")
   ); end of *error*
 (if
   (member
     (setq xdiv:oldPm(getvar "PDMODE"))
     '(0 1)
     ); end member
     (setq xdiv:oldPs(getvar "PDSIZE"))
     (initget "Yes No")
     (setq swMod
     (getkword
       "\nChange points style to good visible? [Yes/No] <Yes>: "))
     (if(null swMod)(setq swMod "Yes"))
     (if
(= swMod "Yes")
   (setvar "PDMODE" 35)
   (setvar "PDSIZE" -2)
  ); end progn
); end if
     ); end progn
   ); end if
 (setq oldOsn
 (getvar "OSMODE")); end setq
 (if
   (not xdiv:curDis)
     (setq xdiv:curDis 1.0
    xdiv:oldDis 1.0); end setq
     ); end if
 (if
    (setq cCurve
   (entsel
       "\nSelect curve > ")); end setq
     (setq cCurve
     (vlax-ename->vla-object
       (car cCurve))); end setq
     (if
(member
  (setq obType
  (vla-get-ObjectName cCurve))
  '("AcDbLine" "AcDbPolyline" "AcDb3dPolyline"
    "AcDbSpline" "AcDbArc" "AcDbCircle" "AcDbEllipse")
  ); end member
  (vla-Highlight cCurve :vlax-true)
  (setvar "OSMODE" 3071)
  (setq stPt
 (vlax-curve-GetStartPoint cCurve)
 enPt
 (vlax-curve-GetEndPoint cCurve)
 fPt
  (getpoint
    "\nPick start markup point at curve > ")
 ); end setq
  (if fPt
     (setq fPt(trans fPt 1 0)
           curPt(vla-AddPoint
      (vlax-3d-point fpt)); end vla-AddPoint
    undoLst
     (list
       (list curPt 0.0 0.0)); end list
    ); end setq
    ); end if
  (if
    (and
      fPt
      (setq fPar
      (vlax-curve-GetParamAtPoint cCurve fPt))
      ); end and
      (if
 (and
   (not(equal fPt stPt 0.0001))
   (not(equal fPt enPt 0.0001))
   ); end or
   (setq dPt
   (getpoint fPt
     "\nPick point at curve to specify markup direction > "))
   (if dPt
            (setq dPt(trans dPt 1 0))); end if
   (if
     (and
       dPt
       (setq dPar
       (vlax-curve-GetParamAtPoint cCurve dPt))
      ); end and
       ); end progn
       (princ "\nEmpty input or point not at curve! ")
     ); end if
   ); end progn
 ); end if
      ); end progn
    ); end if
  ); end progn
(princ "\nInvalid object type! ")
); end if
     (setq maxLen
       (vlax-curve-GetDistAtPoint cCurve enPt)
       (vlax-curve-GetDistAtPoint cCurve stPt)
       ); end -
    rClose
     (vlax-curve-IsClosed cCurve)
    ); end setq
     (if(equal fPt stPt 0.0001)
(setq vClose T)
); end if
     (if
(or
  (and
    dPar
    (> dPar fPar)
    ); end and
  ); end or
(setq posDir T
      sumDis
  (vlax-curve-GetDistAtPoint cCurve fPt)
      ); end setq
(setq sumDis
       (- maxLen
 (- maxLen
  (vlax-curve-GetDistAtPoint cCurve fPt)))
      ); end setq
); end if
            (while(not sFlag)
 (setq whatDo
        (getstring
   (strcat
   "\nSpecify distance or [undo/Quit] <"
   (if xdiv:curDis(rtos xdiv:curDis) "not defined")
     ">: "); end strcat
   ); end getstring
       ); end setq
 (cond
   ((or
      (= 'REAL(type(distof whatDo)))
      (= "" whatDo)
      ); end or
    (if(= "" whatDo)
      (setq xdiv:curDis xdiv:oldDis)
      (setq xdiv:curDis(distof whatDo))
      ); end if
    (setq xdiv:oldDis xdiv:curDis); end setq
     (cond
    (posDir
       (setq sumDis
       (+ sumDis xdiv:curDis)
      curPt
       (vlax-curve-GetPointAtDist cCurve sumDis)
      ); end setq
       (if curPt
         (AddPointOrInsert nil nil nil)
         (princ "\n>>> End of line <<< ")
            ); end if
       ); end condition # 1
    ((not posDir)
       (setq sumDis
       (- sumDis xdiv:curDis)
      curPt
      ); end setq
       (if curPt
            ); end if
    ); end cond
    ); end condition #1
   ((=(strcase whatDo) "Q")
    (if
      (= 1(length undoLst))
       (vla-Delete(caar undoLst))
      ); end if
    (RestorePointStyle)
    (if cCurve
            ); end progn
           ); end if
    (setq sFlag T)
   ((=(strcase whatDo) "U")
    (if
      (and
        undoLst
        (/= 1(length undoLst))
        ); end and
       (setq undoLst(cdr undoLst)
      curPt(cadar undoLst)
      sumDis(- sumDis
        (last
          (car undoLst)))
      ); end setq
       ); end progn
      (princ "\n>>> Nothing to undo <<< ")
      ); end if
   ); end cond
 ); end while
     ); end progn
   (princ "\nEmpty selection! ")
   ); end if
 ); end of xdiv
aquired this code from lpseifert if i remember
Sorry to say I didn't write that code, ASMI gets all the credit.
But you may want to try this pared down version instead.
;places point at specified station along a polyline, measured from start LPS 2008
(defun c:pop ()
(vl-load-com)
(setq oldosnap (getvar "osmode"))
(setvar "osmode" 0)
(command "ucs" "w")
(if (/= (getvar "pdmode") 3)(setvar "pdmode" 3))
(setq ob (entsel "Select curve: "))
(setq p2 (getreal "\n Specify Distance : "))
(setq obj (vlax-ename->vla-object (car ob)))
(setq pt1 (vlax-curve-getPointAtDist Obj p2))
(command "Point" pt1)
(command "ucs" "p")
(setvar "osmode" oldosnap)
I may be missing the point here; but what does the codes in the posts do that the Measure command doesn't do ?
Puts one point on the curve at the specified distance.
[/code]
:D well you shared it; thats credit enough for me.
I use that LISP very often to locate a point along a road or pipe centerline and track its coordinates.
Will try this new one,,,
thanks again :)
lpseifert, sorry, just took a look at the code, and was just wondering does the line.
;end of pop
need to be put in there at the end or am i being daft?
(not know much about lisp yet):oops:
Whilst that is a great option, and I'm not doubting the ability of the code to do what it should; i think it does not answer the OP's request of:
;end of pop
No it isn't necessary... in lisp anything after a ; is a comment
Funny, I don't see ;end of pop in the above code....
no that's what i meant, i thought the code hadn't been closed, didn't realise ; ment comment,
(Can a moderator please move my posts out of this thread and into their own please - don't want to highjack op's qestion/thread)
Sorry totally my fault, just added that lisp as an alternative for this part of the question.
"How do i put a point at a certain distance along the length of a line, i mean, i have a curved line with curves to both side more less like a spline"
That is a sweet routine. It says "along a polyline" but it works on lines and arcs too.
Thank You!!
  • 17 years later...
hi ,I know that the post is too old. I test xdiv code
 (vl-load-com)
   (if
    (setq actDoc
     ); end setq
 ); end =
     ); end if
   (if
(initget "Yes No")
(setq swMod
     (getkword
(if
 (= swMod "Yes")
  ); end progn
 ); end if
); end progn
     ); end if
   (vla-AddPoint
   (setq undoLst
    (append
     (list
(list
 (setq outObj
   (vla-AddPoint
  curPt xdiv:curDis
); end list
      ); end list
 ); end setq
   outObj
 (defun *error*(msg)
   (if cCurve
  ); end progn
); end if
   ); end of *error*
 (if
   (member
     '(0 1)
     ); end member
     (initget "Yes No")
     (setq swMod
     (getkword
     (if
(= swMod "Yes")
  ); end progn
); end if
     ); end progn
   ); end if
 (setq oldOsn
 (if
   (not xdiv:curDis)
     ); end if
 (if
    (setq cCurve
   (entsel
     (setq cCurve
     (if
(member
  (setq obType
  ); end member
  (setq stPt
 enPt
 fPt
  (getpoint
 ); end setq
  (if fPt
           curPt(vla-AddPoint
    undoLst
     (list
    ); end setq
    ); end if
  (if
    (and
      fPt
      (setq fPar
      ); end and
      (if
 (and
   ); end or
   (setq dPt
   (getpoint fPt
   (if dPt
   (if
     (and
       dPt
       (setq dPar
      ); end and
       ); end progn
     ); end if
   ); end progn
 ); end if
      ); end progn
    ); end if
  ); end progn
); end if
     (setq maxLen
       ); end -
    rClose
    ); end setq
(setq vClose T)
); end if
     (if
(or
  (and
    dPar
    (> dPar fPar)
    ); end and
  ); end or
(setq posDir T
      sumDis
      ); end setq
(setq sumDis
       (- maxLen
 (- maxLen
      ); end setq
); end if
            (while(not sFlag)
 (setq whatDo
        (getstring
   (strcat
     ">: "); end strcat
   ); end getstring
       ); end setq
 (cond
   ((or
      (= "" whatDo)
      ); end or
    (if(= "" whatDo)
      ); end if
     (cond
    (posDir
       (setq sumDis
      curPt
      ); end setq
       (if curPt
            ); end if
    ((not posDir)
       (setq sumDis
      curPt
      ); end setq
       (if curPt
            ); end if
    ); end cond
    ); end condition #1
    (if
      ); end if
    (RestorePointStyle)
    (if cCurve
            ); end progn
           ); end if
    (setq sFlag T)
    (if
      (and
        undoLst
        ); end and
      sumDis(- sumDis
        (last
          (car undoLst)))
      ); end setq
       ); end progn
      ); end if
   ); end cond
 ); end while
     ); end progn
   ); end if
 ); end of xdiv
and I see that UNDO not work well. Undo the last post ,but when insert the new point calculate the distanse from the delete point and not from the previous. This is not correct !!!
Can any one fix the code ?
Thanks
Your turn you have 315 posts have a go at fixing. need to save somewhere the second last point co-ords you made.
