Save as DXF increases file size dramatically???
Hi all
Haven’t been on here for a while but have recently started a new job and am having some issues when converting a dwg to dxf.
I have a dwg which is around 300kb but when I save as a dxf the file swells to 2-3mb sometimes more.
I have used PURGE, -PURGE, FILTERS to remove everything possible but it still bloats the file size when I save as dxf.
Does anyone have any ideas as to the problem?
Thanks
I thought that was normal (i.e. - saving as a DXF file increases the overall file size).
And if you zip a DXF file, it shrinks to smaller than a zipped DWG file :shock:
Yep, the DXF file is a text file with lots of waste in it. E.g. instead of a number (say 2,147,483,657) being saved in binary format in a DWG as 32bits (i.e. 4 characters in length) it's saved as a string of characters (2147483657 - 10 characters long). This is just a small increase in what usually happens to DXFs.
The reason a DXF zips to something smaller than the original DWG is that Zip works a lot better with text files than binary files. The DWG is already in binary and the Zip then has trouble trying to compress that as efficiently.
