Im sure this already exist. Does anyone have a lisp to quickly create layers. All I need it to do its create the layer and ask what color I want it on.
Quick + dirty:
(defun c:test ( / name color )
 (while
   (or
     (not (snvalid (setq name (getstring t "\nSpecify Layer Name: "))))
     (tblsearch "LAYER" name)
   (princ "\nLayer Name Invalid or Already Exists.")
 (if (setq color (acad_colordlg 7 nil))
   (entmake
     (list
       (cons 0 "LAYER")
       (cons 100 "AcDbSymbolTableRecord")
       (cons 100 "AcDbLayerTableRecord")
       (cons 2 name)
       (cons 70 0)
       (cons 62 color)
Why should a lisp exist to do such a simple task? There probably is one out there and you no doubt have searched for it.
If you type la at the keyboard, you will get the Layer Properties Manager dialogue box.
If you want to do it all at the command line, then you can type -la, then choose Option M for make a new layer (which will be the current layer), and Option C to choose the colour, as well as a lot more options. :D
Why look for a lisp :shock:
Edited by eldon
beaten by the flying fingers of a Lisp-phile
why does this keep happening? I cant load a lisp. I use APPLOAD to load the new lisp i renamed to "Make Layer". but after I load it it says
"Make Layer.lsp successfully loaded.
Command:
Program ERROR
Resetting environment ; error: An error has occurred inside the *error*
functionbad argument type: consp nil"
and when I type in the key command. it tells me Unknown command "NL". Press F1 for help."
Sounds like you have a LISP loaded that has redefined the *error* function incorrectly.
so how do i troubleshoot?
Open VLIDE, Go to Debug > Break on Error (checked)
Perform the actions that lead to your error.
After error occurs:
Debug > Last Break Source
Then reset your environment by going to:
Debug > Reset to Top Level
Debug > Break on Error (uncheck)
This has been in my startup file for years...
(defun c:LM () (command "-layer" "make" ) (princ))
After error occurs:
Um yeah, I have no idea how this debug things works. how do I "perform the actions" my action is loading a lisp in appload
Then do that.
right.... and I have but it does nothing. I open the vlide. I check the break on error. then go back to the cad window. load the lisp. but it does nothing in the vlide menu. what am I missing?
never mind I figured it out. I was missing a parentheses in the lisp then I copied it.
