I'm using AutoCAD 2011 MEP, we have an enterprize cuix loaded and everything looks and works but when I close AutoCAD and come back into it, I get this message.
'Unable to load customization file:
C:\path\filename.cuix
That Customization Group name already exists.'
It must be embedded somewhere but I can't find it, has anyone come across this situation or know where else I can search out an answer?
Thanks for any help
CAD-B :cry:
I've received a similar error when working with AutoTURN... basically (in my situation) what happened was I tried loading the applicable AT CUIx into our enterprise CUIx, but the add-in itself wants the CUIx loaded as a partial to the Main CUIx instead.
Check to see what is loaded as partials for both your Main, and Ent.
HTH
Thank you, I re-created the enterprize cuix and reloaded it as the partial and it is working without that error. I'm still not sure what I did wrong last time but at least it is fixed.
Thanks,
CAD-B
You do realize that by loading the Enterprise CUIx as a partial to the Main CUIx, it is now editable to all users, right? (
Instead, I was suggesting that you open the CUI Editor, and expand all CUIs and Partials to see what may be loaded twice.
Whatever works for you is your business... just thought I'd share.
