Is there a command to align parts at assembly stage
Hi,
Ive got a complex multi part assembly that contains alot of small parts that each screw in successively on top of each other, but what I wanted to know is... Is there a command that auto aligns the parts on a desired axis or face? Im manually aligning them, but this is a royal pain in the behind....
thanks
QE
Learn to use assembly constraints.
Same thing the person out on the shop floor does with the real parts.
It could be you are interested in iMates, but without a sample dataset....
yeah it was. My fault, I should have deleted the post as I remembered about 5 mins after posting this!!!!!! Clever eh??
You need to have a look at iMates. If set up properly, they can potentially assemble the whole thing for you automatically.
