Hi guys
Can anyone tell me if there is a way to import shape files into Autocad LT?
I have tried using the freeware converters such as Cadtools but have no way of opening the avx file, also tried Import Shape from ABCAutocad but have hit a wall there too. This made me wonder if its even possible in LT.
I managed to install the Import Shape program but it installs a bunch of files I don't think I am able to use. It gives me the following error when I run the SCR it installs. "Command: (defun LISP command is not available."
Any help?
If this is a one time import get a trial version of AutoCAD MAP3D. If you need it full time then look at MapWorks from Dotsoft. Another way is google for shp to dxf converters and use a dxf file with AutoCAD LT.
Thanks guys
I'm snowed under today but will pick this up again on Monday.
Enjoy the weekend.
