Dear All,
Is it posible to create a custom point style that can be applied to existing points within a drawing.
I have a block of a tree wish I wish to apply to existing points in a drawing.
If anything seems unclear please do not hesitate to ask for further details.
TIA,
Minty
Point styles are set, but what you could do is to go to Jeffery Sander's website, scroll down until you find NodeSert which allows you to insert a block at every node in a drawing. Then you could set all your points to be nothing (PDMODE 1). Final effect seems to be near what you are wanting.
What happens when your tree grows isn't a different size or did you stop watering it ?
I would stick with a block for trees you can have different sizes and styles if you want a block at a Autocad POINT v's a CIV3d point it can be done quite easily with a lisp.
If your importing the points in the first place as x,y etc then just search here for a CSV block insert program.
