hidden_br Posted August 1, 2011 Posted August 1, 2011 Hi, I want to open an Autocad file with Marc Mentat,I use import icon,and I change the file type as .igs and .iges,but again I can not see any figure on the monitor,How I can open a .dwg file (auto cad drawing) in Marc Mentat? please help me Quote
JD Mather Posted August 1, 2011 Posted August 1, 2011 What file types will that program open? How are you saving an IGES file in AutoCAD 2007? When you say you, "I change the file type" are you simply using Windows Explorer to rename the file? If so, that is not valid. You will need free Inventor Fusion http://labs.autodesk.com or Inventor 2012 to save as IGES file type. More information is needed. Quote
hidden_br Posted August 1, 2011 Author Posted August 1, 2011 Marc Mentat is a program for FEA like ABAQUS,PATYRAN..etc.I want to stress strain analysis of a hose which was drawn with Auto cad.And unfortunatly I change file type just by renaming it:( I do not know how I save a file as İGES format?How can I do that,please help me?And where should I find Inventor program? Quote
Cad64 Posted August 1, 2011 Posted August 1, 2011 Renaming a file does not change what type of file it is. It is still a .dwg. The link for Autodesk Labs has already been posted, but if you need a more direct link to Fusion, try this one: http://labs.autodesk.com/technologies/fusion/ Quote
