barry2104 Posted August 1, 2011 Posted August 1, 2011 I'd like to know the answer to this... anyone got a fix? for some reason my default value is 1.5560E+99 i want to make the default 1.1 HOW!?!?!?!?!?!?!?!?!?!?! Quote
SLW210 Posted August 1, 2011 Posted August 1, 2011 I have moved your post to its own thread. AFAIK you have to set it in the editor. Might be a LISP around. Quote
BlackBox Posted August 1, 2011 Posted August 1, 2011 Look into DXF Code 45 for the MText Entity. Quote
barry2104 Posted August 5, 2011 Author Posted August 5, 2011 Look into DXF Code 45 for the MText Entity. ooook, so i found the entry on page 71 (79 of 270) but have no idea how/where to edit the code... any more hints? Quote
BlackBox Posted August 5, 2011 Posted August 5, 2011 ooook, so i found the entry on page 71 (79 of 270) but have no idea how/where to edit the code... any more hints? Sorry, I neglected to notice that this thread was in the beginner's area... I do a lot of programming posts. I'll see if I can put something together for you, that will check this value each time a drawing is opened. Quote
barry2104 Posted August 10, 2011 Author Posted August 10, 2011 no luck RenderMan? (or anyone else for that matter) Quote
