Hi there,
I am new to this forum so hello everyone, I have a problem and as this has happened the first time I fire up autoCAD I can see that I am not going to have as easy a time as I did with 3D studio Max.
I found a tutorial on line, and it was talking about the command line, so i was entering points like it said, fine. I had to put it down as something came up at work. Go back to it to play some more, now I can no longer specify points in the command line, pressing space or enter just clears everything and asks to specify a point again.
What have I don't to make this happen, or is it a bug in the program. I have tried restarting again but still no.
Anyone got any ideas?
Kind regards
Rob
A lot will depend directly on which command you were trying to use. What exactly are you trying to do?
Have you tried starting the command first then entering the points when prompted by AutoCAD? Specify first point...
Well yes it goes like this, and I may well have this wrong this is my first time using AutoCAD, I am an engineering student by the way if that helps, so co ordinates are what I want to work with.
Enter 'L' for line
then Enter or try to 'A: 0,0'
this worked the first time I played with it. I then put it down, when I came back there was a prompt for an update (fair enough I have just installed it) three updates later, and now when I press the space bar after the colon, it says invalid entry.
This is very confusing for me, as I was simply following a tutorial online and copying exactly what it says.
I just enter the X,Y coordinates without anything preceding it.
Ohhh! THAT explains everything. :lol::P
Perhaps this example will help (red was manually typed at the command line):
Command: [color=red]L[/color]
LINE Specify first point: [color=red]0,0[/color]
Specify next point or [undo]: @[color=red]10,0[/color]
Specify next point or [undo]: [color=red]<Enter_NotShown>[/color]
Command:
HTH
Enter 'L' for line
then Enter or try to 'A: 0,0' ....
.... when I press the space bar after the colon, it says invalid entry.
I don't know what 'A; 0,0' is and you can't ever use the space bar for coordinate entry, that's the same as pressing
To draw a 10x5 rectangle (with Dynamic Input off)
Command: LINE
Specify next point or [undo]: @10,0
Specify next point or [undo]: @0,5
Specify next point or [Close/Undo]: @-10,0
Specify next point or [Close/Undo]: @0,-5
Enter (to end command)
The "@" symbol tells AutoCAD to draw the line relative to the last point.
You can also use the "#" sign instead to specify the absolute coordinate
By default, if you have Dynamic input turned on, AutoCAD defaults to Relative coordinates, so you can omit the "@" symbol, AutoCAD will add it automatically at the command line.
Command: LINE
Specify next point or [undo]: 10,0
Specify next point or [undo]: 0,5
Specify next point or [Close/Undo]: -10,0
Specify next point or [Close/Undo]: 0,-5
Command: LINE
Command: LINE
"Ah, ah, ah! You [forgot to use
][/b]!"
:lol::P
nestly, to clarify a little, when inputing the coordinates, like typing @2
Line, spacebar or enter, 0,0, spacebar or enter, 10,0, spacebar or enter, etc.
@ rkent Yeah, I phrased that badly. Thanks for the clarification :)
@ RenderMan, Code? Pffft. that's not code. :lol:
Perfect answer, thank you very much, that helps me a lot.
Basically the beginners tutorial I was reading was not helpful, I though I was going mad.
and I will try to use code tags in future.
Thanks for your prompt responses guys, that makes this forum very welcoming.
Kind regards
Rob K
