Temisan2009 Posted August 1, 2011 Posted August 1, 2011 I tried importing a 3d model in max which i created in autocad{ i used 3d face to model the faces of the roof from the roof plan }....... After importing the model, i am having it like this..........some faces are showing while other are not...................... autocad 3d face.dwg max file8 3dface.max Quote
ReMark Posted August 1, 2011 Posted August 1, 2011 A duplicate post wasn't necessary. FYI: For future consideration keep in mind that you can edit previous posts. Quote
Cad64 Posted August 2, 2011 Posted August 2, 2011 You just need to flip some of those polygons. Orbit around the model in Studio Max and you will notice that some of the polygons are visible from underneath. Switch to polygon selection mode, select the poly's that are facing the wrong way and then click the "Flip" button. Quote
