Thirukumaran Posted August 2, 2011 Posted August 2, 2011 i was wondering if anyone could help me in converting the attached dwg file to iges. I appreciate your time and effort Thank you Regards Thiru divergingchannel.dwg Quote
ReMark Posted August 2, 2011 Posted August 2, 2011 Well I did the conversion but the file size came to 896KB which I believe is over the limit for uploading a file of this type. Quote
MSasu Posted August 2, 2011 Posted August 2, 2011 Since IGES file format is ASCII, that size will shrink well if will archive it. Regards, Mircea Quote
ReMark Posted August 2, 2011 Posted August 2, 2011 Yeah, it dawned on me right after I posted that the file could be zipped. Here it is. divergingchannel.zip Quote
ReMark Posted August 2, 2011 Posted August 2, 2011 What program did you use convert the file? It can be done in AutoCAD 2012. The same applies to 2011 IF you are on Subscription and downloaded the Bonus Pack. Quote
SLW210 Posted August 2, 2011 Posted August 2, 2011 Not on a subscription. I can convert with 2000i at home. Quote
ReMark Posted August 2, 2011 Posted August 2, 2011 Not on a subscription. I can convert with 2000i at home. You're a truly talented man. Quote
