abishop Posted August 2, 2011 Posted August 2, 2011 Hello all I normally add my centerlines in inventor in the drawing view by right clicking the view and clicking on automated Center lines. For some reason it isn't working??????? Help! Quote
jdits7 Posted August 2, 2011 Posted August 2, 2011 I have found that if you put holes in the sketch and extrude them, the automated centerlines tool doesn't work. It only works if you use the hole command. Quote
MarkFlayler Posted August 3, 2011 Posted August 3, 2011 Did you choose the Revolved items in the Automated Centerlines tool? Can you put any centerlines on manually? Can you attach the part and the drawing for review? Quote
Lazer Posted August 3, 2011 Posted August 3, 2011 I have found that if you put holes in the sketch and extrude them, the automated centerlines tool doesn't work. It only works if you use the hole command. Yes and could well be a good thing, I know lots of people still extrude holes but this will disable other functions. Quote
jdits7 Posted August 3, 2011 Posted August 3, 2011 I totally agree Lazer, I put all of my holes in using the Hole command. I have some people I work with that can't get it through there minds that it is easier this way. Quote
abishop Posted August 3, 2011 Author Posted August 3, 2011 here is the file. Detail B and section A need the center lines. Thanks Spool Handle SV 1.dwg Quote
MarkFlayler Posted August 3, 2011 Posted August 3, 2011 I need the part file too. The drawing contains a link to the part afterall. Quote
abishop Posted August 3, 2011 Author Posted August 3, 2011 here is both files Spool Piston SV 2.dwg Spool Piston SV 2.ipt Quote
MarkFlayler Posted August 9, 2011 Posted August 9, 2011 Seems to work just fine here. Which view are you trying to put them on? Hopefully not the Section View because that would be a no-no practice. If I place them on the Base view it works fine as expected, the Section line just covers it up. Quote
MarkFlayler Posted August 9, 2011 Posted August 9, 2011 If you indeed are trying to put the Centerline on the Section View (after I slap the back of your hand), you could instead just use the normal Centerline tool to manually place this. Quote
abishop Posted August 9, 2011 Author Posted August 9, 2011 It works just fine in the section view on all my other drawings but not this one.?? And a no no is a matter of opinion! Thanks Quote
