I am trying to convert a mesh to solid in AutoCAD 2010 using the CONVTOSOLID command but I get this message . . .
'Mesh not converted because it is not closed or it
self-intersects. Object cannot be converted.'
Is there another way of achieving this?
Thanks
Dave
It sounds as though you have a problem with the underlying geometry that went into creating the mesh. Until you get that fixed I wouldn't think you could proceed any further. Just my opinion.
Can you attach the file here?
Was Sculpt (I don't recall the command line syntax) in r2010?
From AutoCAD Help file.
"Mesh with gaps between faces. Gizmo editing can sometimes result in gaps, or holes between the faces. In some cases, you can close the gaps by smoothing the mesh object."
"Mesh that has self-intersecting boundaries. If you have modified a mesh object so that one or more faces intersect faces in the same object, you cannot convert it to a 3D solid. In some cases, mesh that is not eligible to be converted to a solid object can be converted to a surface."
Edited by ReMark
Started over after banging my head against wall, this time used the LOFT command to create solid. Works a treat, thanks for your replies nonetheless
The basis for a good solid model is good underlying geometry. Bad geometry will produce unexpected results or no results as all. Let's be careful out there OK?
  • 2 weeks later...
The OP had a problem with his geometry that had to be solved first. He did try the CONVTOSOLID command but it failed. He subsequently solved the problem using a different method.
